SDPC
Old 10-23-2012, 06:36 PM   #85
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Originally Posted by Chris-HPS View Post
I agree, you something going on.
Chris
And your help was appreciated. From what I understand the fastlane pump is a modified cts-v pump. Same pump LPE uses minus the fpcm and other goodies. It has 3 settings as far as speed idle, medium and wot. When I first jump on the gas, pressure does rise to 64 psi (this is due to the cts-v regulator) but then falls on it's face. I thought maybe adding the cts-v fpcm would help but was told no.
Voltage should stay at 12.5-12.8 from what I read. I will try to find a pid to monitor that. I posted because I'm no expert on it and am looking for other things to possibly check.
EDIT: I could be wrong with the above assumptions
nyny69 is offline   Reply With Quote
Old 10-23-2012, 10:29 PM   #86
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
I wonder if my BAP is not working?
How can I check?
Measuring my fuel pressure from the OBD and WITH the bap it drops to 48psi.
Do you have a voltmeter? You could check the wire harness to see if it is feeding power?
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 10-23-2012, 10:32 PM   #87
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
But wouldn't I have to do that under boost?
Old 10-24-2012, 05:23 AM   #88
Pistol-whipped
Pistol-whipped's Avatar
Drives: 2010 2SS/RS
Originally Posted by PQ
Originally Posted by KRich2587
Pulse width modulation computer sends a duty cycle to the pump that's how the pressure is controlled
Posted from Camaro5.com App for Android
Ok. So it's a standard and unchanging process.
Pistol-whipped is offline   Reply With Quote
Old 10-24-2012, 08:40 AM   #89
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Regardless, I think you would still see nominal voltage. A voltmeter can display an open circuit, so as long as you're not getting a "0.00" reading, it should give you an idea.
I've used voltmeters to detect far less amounts of current just to ensure a device was providing power.
I'm a noob to BAP. Is it exposed? Would you be able to throw some revs while someone holds the voltmeter to the leads?
573 RWHP 498 RWTQ
Old 10-24-2012, 11:31 AM   #90
PQ
Booooosted.
PQ's Avatar
Not sure if I can get into boost while stationary. I guess I could have my son lay in the back seat to the trunk while I drive into boost and let him measure it.
Old 10-24-2012, 11:38 AM   #91
Supermaro585HP
Drives: 2011 Camaro SS RS
Supermaro585HP is offline   Reply With Quote
Old 10-24-2012, 12:04 PM   #92
PQ
Booooosted.
PQ's Avatar
Old 10-24-2012, 10:14 PM   #93
WheelmanSS
Logic is dead
WheelmanSS's Avatar
I see.... Well,
If you have a voltmeter handy, might be worth a shot.
573 RWHP 498 RWTQ
Old 12-02-2012, 08:36 PM   #94
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
Fitted my ZL1 pump today by making a inspection plate under the seat
So first up I want to thank Mannys2SS for the excellent post that inspired me to cut a hole in my floor.
I got all the necessary pieces together:
Piece of aluminum checker plate to make trap door
Double-sided adhesive rubber weather strip (to between edge of hole and trap door)
Small hex head tek screws
Fuel sender lock tool
Air-operated nibbler
Tin snips
7.5" plate (to draw around to create hole)
8.5" plate (to draw around checker plate to cut out trap door)
First up I removed the bottom of the back seat (won't go into detail, plenty of threads explaining this)
Disconnect battery
Then I found a plastic plate a home that was 7.5" round that I could align using Manny's pics and draw around with a sharpie.
Then I held the end of the fuel lock tool though the adjoining loom hole in under the floor where I was about to drill the hole (to protect everything as I drilled)
I then went through with the air nibbler and tin snips and carefully cut my hole.
BEFORE YOU DO ANYTHING ELSE HERE, VACUUM OVER AND OVER, BLOW OUT WITH COMPRESSED AIR, VACUUM AGAIN, INSPECT CAREFULLY WITH A FLASH LIGHT TO ENSURE THERE ARE NO PIECES OF METAL FILINGS THAT COULD FALL INTO THE FUEL TANK.
From there, I used the larger plate to draw the 8.5" circle onto the checker plate.
Once I'd cut it out, I laid it over the hole, aligning it and then marking the areas with a sharpie that needed to be reshaped.
Once that fitted nicely it was time to remove the old fuel pump.
I put a aluminum roasting tray next to the hole, ready to put the pump into to catch the fuel. Also had plenty of rags and fire extinguisher at the ready.
Remove the top loom plug and the top hose. (Ready to catch fuel in rag).
Use fuel sender removal tool to loosen locking ring and carefully lift out.
CAREFULLY lift out pump. YOU'LL NEED TO TIP IT GENTLY SIDEWAYS TO GET THE FUEL GAUGE FLOAT PAST THE TANK, THEN THE SAME WITH THE BOTTOM HOSE.
LET FUEL DRAIN OUT AS YOU LIFT PUMP OUT AND PUT INTO METAL TRAY AND TAKE OUT OF CAR.
REFIT NEW PUMP IN REVERSE ORDER ... MAKING SURE PIPES, LOOM, LOCKING RING ARE ALL SECURE.
ONCE THE NEW PUMP WAS IN AND SEALED, I THEN SQUIRTED SOME BOTTLED WATER DOWN AROUND THE HOLE TO WASH AWAY ANY EXCESS FUEL AND BLEW DRY WITH COMPRESSED AIR.
I then applied the double sided rubber weather shield tape to the trap door and stuck in place over hole.
Then using the shortest hex head tek screws I could find, carefully screwed in place. I checked for gaps around the edge ... all good!
simon.w is offline   Reply With Quote
Old 12-02-2012, 09:06 PM   #95
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 12-02-2012, 10:27 PM   #96
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Square hole is a lot easier and more room, And no special tool needed to remove pump. Just a chisel and hammer. Cut the hole on 3 sides fold back install pump then put a piece of dynamat over it.
Nitroman28 is offline   Reply With Quote
Old 12-02-2012, 10:34 PM   #97
simon.w
Round hole was easy to do and allowed plenty of room. I went for checker plate so that once it was screwed back in, it provided a more rigid installation.
Bottom line is that it retains higher structural integrity with round hole and checker plate.
Old 12-03-2012, 02:24 PM   #98
MANNYS2SS/RS
Awesome job guys!! It just makes changing out the pump a breeze.
