Cold Air Inductions
Old 12-28-2012, 10:19 PM   #113
Alvin@PCMofNC
Drives: 2010 IOM RSS
To those installing the pump. You do not have to drop the rear K-Frame all the way. We can normally do them in a couple of hours. Also, I recommend the kent moore tool for removing the ring. At the very least get a brass chisel. If you have sparks near a gas vapors your going to have a bad day mmmmmkkkk
Lastly, even if you AFR is OK with the stock pump be wary that you still may have HUGE fuel pressure drops. That may not be such a bad thing in warm weather but we've had cars creep dangerously lean in winter months.
Alvin@PCMofNC is offline   Reply With Quote
Old 12-28-2012, 10:38 PM   #114
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
Originally Posted by ADM PERFORMANCE View Post
We sell them for $252.00
Packaged with our fuel pump controller for $429.00
Andy, what advantages does your controller provide?
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 12-29-2012, 07:51 AM   #115
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
That is a great price for the fuel pump but to add the pump controller you are paying 177 for that alone. It usually sells for 120ish
SSTony is offline   Reply With Quote
Old 12-29-2012, 07:55 AM   #116
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Our ADM SPEC programmed controller is $199.00
What controller are you talking about?
ADM PERFORMANCE is offline   Reply With Quote
Old 12-29-2012, 07:57 AM   #117
ADM PERFORMANCE
It increases fuel pressure above 4000 rpm.Stock LS3/L99 controllers
Cannot do this.
Old 12-29-2012, 07:58 AM   #118
ADM PERFORMANCE
Originally Posted by grocerygetter View Post
got a link to that or do we call if we choose to go that route?
Taking orders over phone.
Old 12-29-2012, 07:59 AM   #119
ADM PERFORMANCE
Originally Posted by Nitroman28 View Post
That's a good deal. I looked on your site when I was looking at the controller but you didn't have the ZL1 pump on the site.
We sell a lot of parts that are not on our site.
Certain items we like to not advertise pricing on due
to Internet whores.
Old 12-29-2012, 10:29 AM   #120
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
Andy does the fuel pump controller require tuning or is it plug and play like the pump?
JHall651 is offline   Reply With Quote
Old 12-29-2012, 10:56 AM   #121
rjacobs
Drives: 2018 ZL1 10spd Hyper Blue
I am going to be having my rear sub frame dropped to do a full bushing upgrade. Wondering if I should get this done at the same time to save from(possibly) ever having to drop the rear sub frame again. Seems like a cheap upgrade. Im eventually going to put a TVS2300 on the car.
rjacobs is offline   Reply With Quote
Old 12-29-2012, 01:59 PM   #122
ADM PERFORMANCE
Only makes sense now as it is only 1 more hour to do it
Old 12-29-2012, 03:06 PM   #123
grocerygetter
instigator
grocerygetter's Avatar
there are some small tweaks to the tune for the adm controller...I know this from a local car.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 01-17-2013, 02:02 AM   #124
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
I wonder if my BAP is not working?
How can I check?
Measuring my fuel pressure from the OBD and WITH the bap it drops to 48psi.
PQ, did you get the ZL1 pump insalled? Did it solve your pressure problems?
I just installed a ZL1 pump and i'm seeing pressure drop on WOT to 48lbs. Unfortunatley i did not log the stock bump and did not cut an access door. I disconnected the BAP and didn't see any change, so I'm guessing the BAP isn't currently working. However, i would expect the ZL1 pump to maintain pressure as I'm just over 600 hp.
I'm going to test my BAP tomorrow...someone gave me a tip to connect your air compressor to the vacume tube at 10psi to test it.
PMJ is offline   Reply With Quote
Old 01-17-2013, 12:30 PM   #125
Unique Auto Depot
Unique Auto Depot's Avatar
Drives: Camaro 2010
our dealer can't pull up any of these part#'s they say to use GM-13579899 so what is the correct part# for these fuel pumps ??
Unique Auto Depot is offline   Reply With Quote
Old 01-17-2013, 12:46 PM   #126
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
I think you also need a new fpcm with a tune tweak
Sent from my Nexus 10
nyny69 is offline   Reply With Quote
