Emblempros
Old 10-17-2012, 10:23 PM   #1
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Disappointing ET with new LTs and DRs.
Well I went to the track tonight for the first time with my new Stainless Works LTs, Nitto NT05s and JRE tune. Ran a slow 13.21@108. Was expecting more. Have seen other cars with similar mods and street tires running 12.5..Car was really bogging out of the hole. Hooking well but not going. DA was about 1600, pretty humid about 75%. Dunno. Will have to call uncle Ted tomorrow and see if my expectations were out of line.
Jeff
2011 SS/RS L99.A6, Stainless Works LTs, Pypes Ex, Haltech CAI, NTo5 DRs,JRE Tune.
2012 Concours 14
jqram35 is offline   Reply With Quote
Old 10-17-2012, 10:52 PM   #2
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Automatic, tried leaving at idle and holding up on the converter. Did better upon the converter.
Factory rims with 315 Nitto NT05s on back OZ racing Ultraaleggra front with Invo 245
Wind speed neglegable
93 Oct
No subs factory weight.
Tire pressure 24 PSI
Front tire 44 psi
Jeff
2012 Concours 14
Old 10-17-2012, 11:20 PM   #3
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Something is off. I ran 12.5 with LT & Exhaust, ADM CAI and tune in really hot and humid weather.
Did you forget to take the traction control and stability off? Your 60ft is killing you for sure.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 10-17-2012, 11:21 PM   #4
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
TC/SC were off.
Jeff
2012 Concours 14
Old 10-17-2012, 11:22 PM   #5
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
I agree about something off. I tried reloading tune.
Jeff
2012 Concours 14
Old 10-17-2012, 11:24 PM   #6
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Running 315 on stock rims isnt the best idea but not sure if thats what hurt you.
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 10-18-2012, 05:09 AM   #7
Denis
Denis's Avatar
Drives: 2010 SS
im in the same boat...best i could pull down was a 13.4 with the mods in my sig. no drag radials though....i really dont know
Old 10-18-2012, 05:14 AM   #8
Neriah
Neriah's Avatar
Drives: 2011 2SS/RS
you sig doesnt show mods?
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake.
Dynatech LT's. Borla ATAK Catback.
Full BMR bushings and suspension.
Neriah is offline   Reply With Quote
Old 10-18-2012, 08:22 AM   #9
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Am aware got these used the other day. Traction was not the issue.
Jeff
2012 Concours 14
Old 10-18-2012, 08:40 AM   #10
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Originally Posted by HRD_WRK View Post
item#5 is real important- temps at run can be a difference of .2/3, cooled down before this run?
93 octage fuel- but was anything less ever installed (fuse pull issue).
weight is too -even fuel amount/body weight ~100lb = 0.1s
-you still have the stock washer tank? try without -much more air access.
-assume you didn't deep stage the tree.
-your RT- i assume you weren't spinning at the start, just light reaction delay.
assume other runs were similar.
your rear tires - not DR -reg NT05. the size is excessively wide for a stock rim-not recommended-and lowering the pressure makes the traction worse due to improper sizing. Extra weight too. More rolling restance at lower psi .You should run them as close to normal, until you start to have too much slip. no water box. spin to clean and minor heat (on good track).
I'm actually out of town w/o access to 99% of my slips. My initial thoughts at 1600da no wind, no heat soak/temps <+192:
your 60ft should be 1.9 or better
your 1/4 should be easily under 13.0
your slip looks consistent, although a little slower et/mph than I'd expect even for that 60ft = more weight/hotter/higher rolling resistance than my typical at that 60ft when with less mods and stock wheels.
I'd recommend working on your 60 (i've been 1.8s on stock wheels and CAI), then worry about the rest later.
good luck
Tim
I've had the car a while now and have done the fuse pull a while ago. Did not really notice any difference. Never had anything but 93.
I have never weighted the car and probably wont. It had about 3/4 tank of gas.
Did a bit of research on the tire and that was the recommended PSI for best traction. 20-25. I left it 24-25 PSI. Really doubt it would have that great of an effect.
Do still have the factory washer bottle will look into that.
Not really anything to work with to improve 60 ft. Tried launching several different ways and none worked. You see the best one above. Not my first rodeo either. Have had numerous toys. My 00 Firehawk ran 12.7. 69 Firebird that ran 11s back in the day.
Don't think the car is running like it should be.
Jeff
2012 Concours 14
Old 10-18-2012, 08:45 AM   #11
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Sounds like your tune is pulling timing right off the hit at low rpms! This happens to me!!!! You know what fixed it, running a few gals of 100 octane makes my car a different animal on the low side of the power curve! I cant tell you I have a laptop hooked up for my runs and seeing this happen, but I have done it twice with the same out come! Run without the racing gas and my car is lacking low speed power under heavy load, put a 100 in her and its like I picked up 50tq at low rpms! My runs with the racing gas end up with better 60s and more 1/8th mile speed, but does nothing for top end. SO what seems to be happening is my timing is being pulled because of crappy gas and run conditions.
Give it a shot... Your car should be mid 12s all day man!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 10-18-2012, 08:56 AM   #12
Denis
Denis's Avatar
Drives: 2010 SS
oops HAHA
halltech cai, tsp long tubes, no cats, corsa cat back and a JRE tune
Old 10-18-2012, 08:57 AM   #13
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Temps were in the mid 70s, humidity also in the mid 70s.
Jeff
2012 Concours 14
Old 10-18-2012, 09:30 AM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Can be a few things, but the first thing to do is fix that 60 ft time. I've gone 1.86 with the same parts I think you have (mine are in sig).
Does your tuner have your fans coming on sooner? Makes a difference.
Try to get your incrementals more like mine:
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
