JUICEDMOTORSPORTS
Old 10-18-2012, 10:03 PM   #1
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
Stock 2012 LS3 SS Edelbrock E-Force Question
Plain and simple... will it be completely safe to install E-force Street kit with edelbrock pre-programmed tune and nothing else? I read all these things about fuel pumps, injectors, rails, etc... I was going to leave my Camaro stock but have started to get the force induction itch. So I started to look into S/C and I saw the stock, clean looking E-Force. I thought that it was pretty much bolt on and go but the more I read on here the more I get nervous about running it stock. Im not looking to go crazy with boost or hp, just want a little more bite to my daily driver. Can I get some input before I pull the trigger? Thx all.
JHall651 is offline   Reply With Quote
Old 10-19-2012, 12:27 AM   #2
JHall651
JHall651's Avatar
Anyone?
Old 10-19-2012, 12:35 AM   #3
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Stock with just sc is fine, but you will need the Jannetty fuel line fix and toss the canned tune. Do yourself a favor and have a custom tune regardless of your end goals it will be probably the best thing you do..
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 10-19-2012, 12:39 AM   #4
Rockey33
Rockey33's Avatar
Drives: 2012 IOM Camaro SS
Thinking about getting the same supercharger.
Rockey33 is offline   Reply With Quote
Old 10-19-2012, 12:46 AM   #5
JHall651
JHall651's Avatar
What is the Jannetty fuel line fix and why do I need it?
Old 10-19-2012, 02:06 AM   #6
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
its basically a Y block and lines that feed both fuel rails equal fuel as the one that comes with the e-force isnt really that great. its only like 100 bucks or something and well worth it.
Oxtar41 is offline   Reply With Quote
Old 10-19-2012, 07:39 AM   #7
LyonsViper27
Drives: 2011 1SS/RS - JRE 415
Just bought mine will be here monday so pumped!! got the jre fuel rail mod why risk it?
Black '11 SS/RS 1 7/8 Dynatech Stainless Headers, Cold Air Inductions CAI, E-force, JRE Tune - SOLD
LyonsViper27 is offline   Reply With Quote
Old 10-19-2012, 08:13 AM   #8
epstein
Drives: SS/RS
Send a message via AIM to epstein
JRE Line is a MUST,..... with the canned tune You'll be very safe, but you will greatly Benefit from a custom tune. Your car will run more efficient burn less gas and idle better. I installed mine with about 2,000 miles on the clock and am now at 25,000 . It has been a Blast . As with Others If you are doing the install yourself and have Any questions Reach out and hit me up. I have helped many with an answer or a picture during an install.
Brian
epstein is offline   Reply With Quote
Old 10-19-2012, 08:29 AM   #9
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Another must is pinning the crank, replacing the injectors.......
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 10-19-2012, 09:03 AM   #10
LyonsViper27
Crank pinning and "upgraded injectors" are included with the kit and teds tune of course, the eforce injectors wont be in there long, going to do a lpe dual pump and a set of ID850's.
Old 10-19-2012, 09:07 AM   #11
JHall651
JHall651's Avatar
Here we go.... This is what I was afraid of. Now it's fuel injectors. Like the 52's are not good enough to run on stock car with super conservative pre-program tune? What do mean by pinning the crank? Again I know there is a slew of thing we can do to this car, I'm just starting with S/c and I just want to make sure it's safe to do that.
Old 10-19-2012, 09:33 AM   #12
LyonsViper27
Pinning the crank basically is just keeps the balancer from spinning on the crank shaft, I pretty sure all the kits come with this. the injectors are ok for the base kit with some supporting mods. If you are going to do any more then the stock kit upgraded injectors and a fuel pump upgrade is a wise choice
Old 10-19-2012, 10:28 AM   #13
JHall651
JHall651's Avatar
Oh pinning the crank is that step where you drill the the hole with the guide. I gotch ya. Is there people who actually skip this step? That seems like it would be a very stupid step to omit. Is there a way to check and make sure you are getting adequate fuel supply from the pump and injectors with out have to install anything?
Old 10-19-2012, 10:35 AM   #14
LyonsViper27
You want to look at fuel pressure for the pump and the duty cycle on the injectors, you should be able to look up the duty cycle with a scan tool depending on which one you use. as far a fuel pressure your going to need a gauge of some sort. you can search this forum and find the power levels that most people are running out of fuel and base your needs off that. just dont skimp on your fuel system
e-force, edelbrock, safe, stock, supercharger
