Old 10-18-2012, 10:39 PM   #1
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Drives: 2010 2SS/RS CGM
bad to use microfiber pads on buffer?
I just recently bought my first orbital buffer. I see alto of people use foam pads. I dint have those i use microfilm pads. Are they not as good? I only wax no polishing. Thanks for the input!!!
JBA 1 7/8 LT`s, High flow mids, and Cat back,Airaid intake, JRE Tune, & alot of flat black....
CyberBri is offline   Reply With Quote
Old 10-18-2012, 10:51 PM   #2
Jeffm
ICANHAZ
Jeffm's Avatar
Drives: 2013 CRT 1SS/RS
which buffer>?
Jeffm is offline   Reply With Quote
Old 10-18-2012, 10:53 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Microfiber pads are actually more effective on an orbital.
*In life, there are no nandroids*
[B]
Old 10-19-2012, 10:00 AM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Microfiber pad or microfiber bonnet? Someone asked a similar question the other day, I assumed pad, but turned out they had a 10" bonnet polisher so it all got a bit confused.
Old 10-19-2012, 07:12 PM   #5
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
the bonnet...the buffer is from discount lol its a 10 inch orbital
Old 10-19-2012, 07:29 PM   #6
CamaroDreams07
Drives: Slow V6
OK I retract my statement.
[B]
Old 10-19-2012, 08:03 PM   #7
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Y
Old 10-20-2012, 10:12 AM   #8
Adam's Polishes
In that case you're probably better off just working by hand. A tool like that is pretty much only good for removing the residues from waxing, and even then I don't trust the quality of the microfiber bonnet that comes with most of them.
Old 10-20-2012, 10:15 AM   #9
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
All i use it for is to put wax on and take it off. I got some different microfiber bonnets for it. Arent all orbital buffers the same they make a low speed rotation????
