BORLA
Old 06-03-2009, 07:52 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
ADM Performance does does aeroforce interceptor install
ADM Performance specializes in custom manufacturing performance parts for Gm vehicles,we also specialize in custom installs.With over 25 years of design and integration we go the extra mile when it comes to true OEM quality installs.
Recently there has been growing concern on where to put any aftermarket gauges in the 2010 Camaro.With this concern we took it upon ourselves to create the first integrated gauge/gauges into the dash of the Camaro.
We took a product we have been selling for several years now,it's called the Aeroforce Interceptor .
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display. A sample list is below...
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
ADM Performance stocks many different color combinations of the Interceptor,But my favorite is the one pictured.
Andy
www.admperformance.com
214-228-8782
Mon-thur - 9:30-3:30
ADM PERFORMANCE is offline   Reply With Quote
Old 06-03-2009, 08:37 PM   #2
redd214
Drives: 95 Impala SS
damn that looks clean!! more pics more pics!!!
redd214 is offline   Reply With Quote
Old 06-03-2009, 09:09 PM   #3
Shocker
Future 5th Gen Owner
Shocker's Avatar
Drives: 2004 Pontiac GTO
sweet install
Future Owner of a5th Gen Black/Black and more Black RS/SS
For now a lightly modded 04 GTO
Shocker is offline   Reply With Quote
Old 06-03-2009, 09:25 PM   #4
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I had one of these gauges in my SRT4... best company and gauge to get hands down.
franknbeans is offline   Reply With Quote
Old 06-03-2009, 09:39 PM   #5
ADM PERFORMANCE
ADM Performance -Aeroforce Interceptor 2010 Camaro
http://www.aeroforcetech.com/action.html
RPM
MPH
Fuel Temperature
Battery Voltage
Battery Temp
Long Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Knock Retard
Engine Load
Transmission Slip
Brake pressure
Steering Angle
Lateral G's
Yaw
Andy
214-228-8782
Old 06-03-2009, 09:41 PM   #6
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I need a price...I am interested in one for my project.
ZZcamaro is offline   Reply With Quote
Old 06-03-2009, 09:48 PM   #7
ADM PERFORMANCE
Interceptor price
Due to the complex install we will offer this setup to ADM inhouse customers only.
I will be in contact with the manufacturer to see if we can possibly work together on having remote components for custom installs like this one.
Current price for 1 gauge is $239.00
Custom installed - Interceptor only - $759.00
Interceptor with 2 bar boost sensor - $859.00
Interceptor with wideband installed - $1299.00
Interceptor with wideband and 2 bar boost sensor - $1399.00
Dual gauges with cnc painted bezel available for additional cost.
All of the above come with cnc cut oem painted trim bezel.
Andy
Old 06-03-2009, 11:34 PM   #8
blackedout010
Drives: on order black 2010 2ss
very nice!!
blackedout010 is offline   Reply With Quote
Old 06-04-2009, 02:32 AM   #9
RobbRock
Consultant Camino Real
RobbRock's Avatar
Drives: 2010 2SS Camaro
Send a message via AIM to RobbRock
Nice
RobbRock is offline   Reply With Quote
Old 06-04-2009, 05:13 PM   #10
Morepwr
woohoo
Morepwr's Avatar
Drives: Silverado, 70cutlass, 57chevy&more
Damn! Thats one of the coolest things I have seen! What a great gauge set up that is!
I am not useless, I can still be used as a bad example!
Morepwr is offline   Reply With Quote
Old 06-04-2009, 05:20 PM   #11
optical
The Pilot
optical's Avatar
Drives: 1993 Chevy C1500 Ext Cab, 5.7L
That looks slick! awesome!
Driving: 1993 C1500 Ext Cab Truck, 5.7L, BF Goodrich All-Terrains, Named: "SexyTruck"
Future Car: 2011 IOM Camaro 2SS/RS Manual, Black Stripes, Hurst Short-Throw, IO Interior!
optical is offline   Reply With Quote
Old 06-04-2009, 05:21 PM   #12
alex33x
Drives: 2013 Camaro ZL1
Nice! ADM does it again!
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 06-04-2009, 05:24 PM   #13
ssrsheaven
ssrsheaven's Avatar
Drives: 92 firebird,2010 camaro
Nice I like where can I get mine at?
ssrsheaven is offline   Reply With Quote
Old 06-04-2009, 05:26 PM   #14
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Very nice.
Can we make better thread titles though?
MerF is offline   Reply With Quote
Songs About Camaros (for your driving pleasure) Emjay 5th Gen Camaro SS LS LT General Discussions 74 12-18-2014 01:42 AM
10 Camaros that should be built SSOOCH 5th Gen Camaro SS LS LT General Discussions 47 11-03-2009 06:46 PM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
Fesler-Moss Camaro Announced swchopper 5th Gen Camaro SS LS LT General Discussions 72 05-07-2009 10:40 AM
