JUICEDMOTORSPORTS
Old 10-24-2012, 08:15 PM   #57
Rob@WretchedMS
Drives: His Wife Crazy
I have not heard of any issues,
As for the weather, it will not be an issue.
I have 2 cars will complete Pedders kits on them, and i live in New England.
Both cars are driven in the snow, there have been zero problems with the weather.
Rob@WretchedMS is offline   Reply With Quote
Old 10-24-2012, 08:54 PM   #58
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Originally Posted by Rob@WretchedMS View Post
I have not heard of any issues.
From the "EP6579 Front Radius Rod HD Inserts" description on your website:
This solution is extremely firm and may lead to premature wear in the tie rod ends or the steering rack.
Dexman1349 is offline   Reply With Quote
Old 10-24-2012, 09:02 PM   #59
Rob@WretchedMS
it's a precautionary statement, we have had no problems to date.
It's something that you should be aware of before purchasing, but the same can be said of any bush or insert that limits travel.
Old 10-24-2012, 09:08 PM   #60
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Are the HD (street Z kit) inserts GMPP approved too?
Old 10-24-2012, 09:28 PM   #61
Rob@WretchedMS
let me verify before i commit
Old 10-24-2012, 10:47 PM   #62
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Yes, they are. Our radius bush inserts were the idea of a GM engineer working on the Grand Am prototype that now is built by Riley. The engineer asked for a urethane replacement for the OE rubber snubber in the radius bushes. We did a duplicate of the OE now called the EP6578. Being Pedders, we decided to take the idea a few steps further. The result is the EP6579. We made about twenty sets for GM to evealuate, but they were side tracked with a bad economy. After a bit I asked about the project status and was told to I could sell them as Pedders parts.
Old 10-26-2012, 11:17 AM   #63
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
With what's been discussed, it looks like I will probably go with Pedders 27mm sways (front & rear) with the Street Z kit. I just need to wait for a couple of checks from the bank (recent refi) to come in before I can pull the trigger on this.
I will definitely post my review once I get everything installed!!
Thanks again for all the help & advice!!
Old 11-09-2012, 02:35 PM   #64
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Stupid F-ing bank screwed me out of some serious $. Looks like I will probably just be left going with the Street Z kit and have to wait until next spring for sways. Dammit.
Old 11-21-2012, 02:45 PM   #65
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Question for the Pedders guys out there: Why do all of the pictures of the 27mm Front & rear bars show what appears to be 4 front end links?
The other kits seem to show different sized end links
I've crawled underneath my car and it looks like the 2nd pic is more accurate where the fronts are ~15" long and the rears are ~5". I just don't see how the endlinks from the 1st pic would work.
Old 11-21-2012, 03:05 PM   #66
caverman
caverman's Avatar
Drives: '69 SS Convertible
There are 4 endlinks as you have seen. There are the tall ones in front, small in back. My guess is the first pic has a mistake and has two sets of fronts. The second pic is more accurate.
BTW: you should look into converting over to the new FE4 suspension while you're at it.
Build Journal
Old 11-21-2012, 03:25 PM   #67
Rob@WretchedMS
We are working on updated pics, we just didn't have the correct pics to upload.
Old 11-23-2012, 07:35 PM   #68
ramsman34
ramsman34's Avatar
Drives: 2011 Summit White, 2SS/RS-LS3
Here is what I did and noticed a big difference when driving mountain and canyon roads EP 6579 and EP 1201. I have no other suspension mods, stock tire size, Hawk ceramic brake pads, and I am at 414 RWHP. I can carve winding canyon roads harder than my brakes and tires can handle. I am going with more bushings, ZL1 style sways and coilovers for wither Pfadt or Pedders, or a combo of parts from both next. I, like you use my camaro as a daily and commuter driver and here in So Cal we have a lot of canyon roads that are a blast to tear up.
414whp, 403wtq (Mustang Dyno) -Thanks Ray/Full Throttle Kustomz
ramsman34 is offline   Reply With Quote
Old 11-26-2012, 03:17 PM   #69
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I'm still trying to figure out how to get the swaybars and endlinks that I want, the challenge comes from finding a way to pay for them without adding more debt to the credit cards...
I've installed the EP1201 inserts and noticed a subtle difference in the handling, and am in the process of acquiring the EP6579's. I will probably add the EP 2112 (steering rack bushing) to the mix when I get the sways, just because it seems like an inexpensive upgrade to do while I have the front disassembled and in need of an alignment.
Old 11-26-2012, 03:25 PM   #70
JusticePete
VIR Specialist
Does 0% Debt sound Better?
