Old 12-10-2012, 09:35 AM   #29
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Originally Posted by tramtwo View Post
What! Do you have an oil cap breather from the factory? Looks like a vaccum line running from the cap. Didnt know they started doing that.
Old 12-10-2012, 09:57 AM   #30
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
This is a GM Oil Separator similar to the one one the zl1. It is made for off road use only but some dealerships don't know and are installing them.
tramtwo is offline   Reply With Quote
Old 12-10-2012, 10:23 AM   #31
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
This is after about 150 miles. Install a separate clutch reservoir and keep this clutch dust in check.
Old 12-10-2012, 10:45 AM   #32
trewyn15
trewyn15's Avatar
Drives: 2004 Monte Carlo LS
Do you have more on how exactly this is done? Is it the same issue with the SS models also?
So far this is a sweet build, that car is beautiful! I like the deep look of the tails also
2004 Monte Carlo LS - 1966 AMC Rambler Rebel Classic - 2000 Trans Am WS6
trewyn15 is offline   Reply With Quote
Old 12-10-2012, 10:56 AM   #33
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Yes all LS3s have the problem. There is a ton on the forum about the whys and what fors. You can start here.
Old 12-10-2012, 11:31 AM   #34
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
Sweet car!! Love what your doing with it!!!
swizlstik is offline   Reply With Quote
Old 12-10-2012, 02:06 PM   #35
Ivan @ Southwest Speed
Looks hella nice! Love the color!!
Congrats!
Ivan
Old 12-10-2012, 03:19 PM   #36
Denis
Denis's Avatar
Drives: 2010 SS
well is there an issue if its installed by the dealer? i mean is it a warranty voiding thing since its "off road use only"?
Old 12-10-2012, 03:26 PM   #37
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Nope... just means your dealer is dumb.
It is just a fancy vented cap.
Old 12-10-2012, 04:39 PM   #38
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Rainy day lunch time easy mods (please don't tell my therapist)
The first is the dash center speaker delete. This helps with the stereo separation and gives the system a better (cleaner) sound.
The speaker cover comes off fairly easy using a trim removal tool. (can get a pack of these for about 10 bucks) Make sure that you pop it up on all for side FIRST and then bring it back towards you to remove.
The speaker is held down with two screws. I just used a small crescent wrench to break em free and then backed them out by hand very easy.
The OEM connector unplugs by pressing in the release (detent) and pulling straight down.
Using my favorite modding device I tie wrapped the connector to keep it from rattling.
You want to make sure you place the cover back on front (towards engine not you ) to rear. Notice the three tabs.
As a bonus you can shed a entire 8 ozs of weight!!
Old 12-10-2012, 04:50 PM   #39
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Next is to replace the harsh map light bulb with an LED. Pick ya color (yeah white is a color) and it burns WAY cooler.
Once again using the trusty trim tool remove the cover.
You want to make sure to loosen and then pull straight down. Pretty much with all the connectors on this car you do not want to pull at angles.
These are the replacement bulbs erum (sorry I am old school I mean LEDs) I used.
This blue is a PERFECT match to the GM Ice Blue used in the gauges and the door.
The cover just snaps back into place. Here is the finished product.
Old 12-10-2012, 09:25 PM   #40
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Nice Ride!!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 12-10-2012, 11:07 PM   #41
MR 45TH
Drives: 2016 2SS
Love it!!! Keep up the pics.
ProCharger P1-X
542hp 528tq on 6PSI
MR 45TH is offline   Reply With Quote
Old 12-10-2012, 11:57 PM   #42
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
A little mood lighting.
