Cold Air Inductions
Old 10-20-2012, 02:15 PM   #1
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
V6 top speed runs
Hello all, I have sort of a dilemma, Ive been trying to do some top speed runs in my 2012 Ls m6, i have a cat back Solo Exhaust, and K&N drop-in filter. I also took out the spare tire in the trunk to save some weight. However i cant seem to get past 120-125 , so idk if im doing something wrong? Do i need a tune or something? Any suggestions are appreciated Thanks
mdiaz0618 is offline   Reply With Quote
Old 10-20-2012, 02:17 PM   #2
VR1LE
lighten up Francis
VR1LE's Avatar
Drives: 2013 Camaro 1LE
what happens at 125mph? does it hit the limiter or just sits there at 125?
1SS 1LE track rat ordered 10/19
Arrived at dealer 12/26/12 after hours delivery
VR1LE is offline   Reply With Quote
Old 10-20-2012, 02:18 PM   #3
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
it just sits at 125 and im like flooring it in 6th
Old 10-20-2012, 02:19 PM   #4
VR1LE
lighten up Francis
VR1LE's Avatar
when you redline the 5th to 6th shift about what MPH are you at?
Old 10-20-2012, 02:22 PM   #5
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
damnn i really havent redlined it lol what rpm should i be in 5th?
Old 10-20-2012, 02:51 PM   #6
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Thought LS's with steel wheels are limited to 118mph unless you have a tune
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 10-20-2012, 02:53 PM   #7
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
oh wow i forgot to say i have the rs 20's on it if that makes a difference?
Old 10-20-2012, 03:03 PM   #8
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
Nothing to do with the wheels, LS are set to 118 top speed, LT to 125+... You need a tune to over past that speed...
Monchy36 is offline   Reply With Quote
Old 10-20-2012, 03:29 PM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
As mentioned, your car must be speed limited (electronically speed limited). You'll need a tune to delete the speed limiter.
But I thought all the cars that come with 20" wheels were limited to 158 mph.
Old 10-20-2012, 03:46 PM   #10
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
wow ok, can someone link me to a 2012 v6 tune page?
Old 10-20-2012, 05:52 PM   #11
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
If your looking at getting a tune go with trifecta. Just do a search on the forum there is a ton of info about it.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 10-24-2012, 07:24 PM   #12
Untouchable Keeve
Drives: 2011 1LT
What RPM are you at when you're in 6th? You may want to try to downshift and see if you're just not shifting too early. I have an A6 1LT (limited to 118) and I sit around 4000 RPM as I hit 118.
Untouchable Keeve is offline   Reply With Quote
Old 11-07-2012, 09:26 PM   #13
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
This is so simple. MDiaz's car is an LS. All LS models were ORIGINALLY equipped with the 18" steel wheels with the T-rated tires, and limited to 118 mph. If the owner at some point optioned up or added wheels after-market, the limiter is set at 118. The slight difference in circumference of his wheel/tire combination that's presently on the car is showing up as an erroneous reading on the speedometer.
The car will not go faster in any gear, at any RPM. But it could. It has to be tuned out, as most of the other posters mentioned.
You also have to make sure you have tires rated for that higher speed. What's the letter speed designation on your tire sidewall, MD?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 11-07-2012, 09:48 PM   #14
429
Drives: 2010 camaro ss
your top speed will be in fourth or fifth gear, not sixth
429 is offline   Reply With Quote
