Old 10-20-2012, 05:56 PM   #1
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
Does the ZL1 need a driveshaft safety loop for NHRA sub 11.5?
So a debate ensued last night on how a ZL1 Camaro isn't NHRA legal to run faster than 11.5 without a driveshaft safety loop. Given the placement of the driveshaft in the chassis per the link here,
http://gmauthority.com/blog/2012/10/...dy-with-video/
How would it be possible for a broken driveshaft to escape from this car? Additionally, it looks like you'd actually have to cut and modify quite a bit to even make room for a "safety" loop wouldn't you?
I do understand NHRA has roll cage requirements too but I'm only curious on the driveshaft loop. It seems redundant with this design and the draveshaft is already sufficiently contained with the factory design.
1st Gen Forever is offline   Reply With Quote
Old 10-20-2012, 06:29 PM   #2
HDRDTD
Doesn't matter how the driveshaft in the ZL1 is routed. NHRA rules state it must have a safety loop if the car is faster than a certain ET.
Rules are rules.
Old 10-20-2012, 06:40 PM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
The loop is also there to stop the driveshaft from coming through the transmission tunnel. When they let go at the front they bang around hard.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 10-20-2012, 06:41 PM   #4
james347
Drives: 2006 Crownline
Upon inspection, there does seem to be a lot of protection against a drive shaft coming loose and doing damage. But is all of that really designed to keep a drive shaft 'in place' once it breaks? Probably not. It will wreck havoc on the underneath of that car and with some very stealth safety loops on the market, I would definitely invest in one to keep it from tearing up that undercarriage.
james347 is offline   Reply With Quote
Old 10-20-2012, 07:22 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
metco makes one for an SS that may fit a ZL1. http://kdinnovations.com/camaro_file...ccessories.php
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-20-2012, 07:23 PM   #6
Stephen12ZL1
Drives: '17 ZL1 A10
here ia another one that may work
http://www.jegs.com/i/Lakewood/620/1...oductId=751248
Old 10-20-2012, 07:28 PM   #7
Stephen12ZL1
Drives: '17 ZL1 A10
better read the rules...wow! fire extinguisher too!
http://mustangpartstech.com/General_...uirements.html
Old 10-20-2012, 08:34 PM   #8
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
The driveshaft loop has to be within 6 inches of the front U joint.
I'd like to know if the aftermarket axle rule would be needed on the ZL1.
hairtrigger is offline   Reply With Quote
Old 10-20-2012, 08:45 PM   #9
1st Gen Forever
ZL1 #140
Also, isn't the Camaro a split drive shaft with a u-joint secured to the chassis in the middle?
So not only do you have multiple "front" u-joints if you will from a perspective of what can break, but the length of each when broken free is not like that of a full drive shaft in our older cars.
It just seems the NHRA rules might need some updating in general. At what point are we no longer making changes to our cars that improve safety but rather just checking off boxes because "That's the way it's always been"?
Old 10-20-2012, 08:55 PM   #10
DrkPhx
DrkPhx's Avatar
you also need a roll bar if you run 11.49 or quicker. Even though my previous car had all of the required safety equipment; I've been to several tracks over the years and I have never seen a tech actually get under a car and look for a driveshaft loop. It's too much hassle and takes too long especially on race day with a packed track.
