BORLA
Old 11-01-2012, 08:15 AM   #43
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
Originally Posted by litle88 View Post
That's awesome!
Not that hard hu? Are you checking your PTV? It's easy too, I used clay. Just need about 2-3 bolt on the head. No torquing down just a Lil tightening. You got valve reliefs but you know me, cautious and piece of mind lol.
Not too bad! Once you know what to check, it makes good sense.
Yep, that's the plan to check PtV as well. I was going to use the clay method you mentioned as well as the dial indicator on the spring retainer. I guess one method can be sufficient but I want to go through the excercise.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 11-01-2012, 09:25 AM   #44
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Are you going to tune the engine and transmission? I like this write up keep up the good work.
Old 11-01-2012, 09:30 AM   #45
1Camaro2SS
1Camaro2SS's Avatar
Yes, I will have it tuned on a dyno. Thanks, glad you like it.
Old 11-02-2012, 09:28 AM   #46
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Just curious why you pulled the motor to do the LS3 conversion?
Nitroman28 is online now   Reply With Quote
Old 11-02-2012, 09:33 AM   #47
1Camaro2SS
1Camaro2SS's Avatar
I'm installing a new torque converter as well so I had to either pull the engine or the trans. Since the engine needed a lot of work, I might as well pull it out and be in a better position to do the work. I also wanted to install a new oil pan gasket which is impossible to do unless you raise the engine several inches. Its so much better to work on the engine this way. I am able to rotate the engine on the stand and get a really good view of what I'm working on.
Old 11-02-2012, 11:56 AM   #48
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
It is easier to pull the engine to do the work as i did all of this and more to my L99, the only difference is i dropped my whole front rolling chassis below the car, it is much easier to drop the motor then to pull it out of the engine bay upwards!
Pretty easy job if you have the time and patience!
Old 11-02-2012, 01:07 PM   #49
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Wow great to see someone turning wrenches like this. Please keep the pictures coming!
I will be installing a Cam/oil pump/c5R timing set/valve springs this coming spring on my ls3. with the tranmission issues that they are known for I almost wish I got the l99.
Any suggestions for cams? lol
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 11-02-2012, 05:04 PM   #50
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Markmass, How do you like your cam and 3200 stall? Is 3200 sufficient?
Sorry mate -- just seen this
The 3200 stall is fine - it really helps --- basically couldn't drive with a stock TC!
I have a pretty aggressive CAM.. GET-TORQ have it for a couple of days (pick up tomorrow) fine tuning and adding J-pipes to the SOLO Mach-XL to deaden the resonator drone at 1800rpm. I have the Torque management turned off, so the gear changes are quick, and noticeable (cant really describe it) anyway they are tinkering with the line pressure to relax the changes in 'D', but aggressive in 'M'. Fuel economy --- errmmm don't ask!! but you will so....on a run I am probably at 17MPG. pure city is probably 8 to 9 - mix is around 12-13. but i probably drive 4k a year, no commute - so no biggie
I get some very light and occasional bucking up to 1400 rpm, its not a problem, and again i am sure the multi-disk TC soaks some of that up (i think??)
Overall - I love it - the sound is perfect - i could get a deck chair, a cold one, and listen to it all day!, the power is just outrageous over stock. I took it to a couple of small shows last week (Sawgrass Ford!!) it attracted a lot of attention particularly when fired up.
Looking forward to the updates!
Cheers
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 11-02-2012, 06:22 PM   #51
Cpanthers85
Drives: 2011 Camaro 2SS RS
What did you decide on for the L99 wiring harness for the cam phaser?
Looks really good! You are def taking a lot longer time to clean things thoroughly than I did... Lol I just wanted the SC on!!!
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 11-03-2012, 10:56 AM   #52
1Camaro2SS
1Camaro2SS's Avatar
With so much debate over stuck oil pump or Melling, I decided to go with the Melling since it was cheap. Still not convinced its a better pump but i don't want to get into that now. I added a photo of the oil pump install using feeler gauges. Im feeling good about this one!
Old 11-03-2012, 10:59 AM   #53
1Camaro2SS
1Camaro2SS's Avatar
Cheers
Sounds awesome man. I decided to go with a 3600 stall based on recommendations although 3200 would have been fine also.
Old 11-03-2012, 11:06 AM   #54
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I used a razor blade and scraped off the thick layer from the flat areas then I used scotch Brite pads along with sea foam but that dint work so well. I then used the pads with Scrubbing Bubbles (bathroom cleaner) to make the really clean. This was all done with piston at TDC and engine rotated on the side to avoid crap from going in the cylinder. I also used a shop vac and contantly vacuumed around the piston area.
I used steel wool and seafoam. I coated my cylinder walls with oil really good so that if anything got in there it would just wipe out without scraping the walls.
Old 11-03-2012, 11:20 AM   #55
1Camaro2SS
1Camaro2SS's Avatar
Yes that was another option. I lifted the engine from the top since my friend had the lift and let me borrow it.
Thanks and good luck with your install also. I am using the Comp LSr 231 247 .617 .621 cam. this is one of their off the shelf cams.
I started to modify the bracket but I don't like it. I may order an LS3 bracket and go from there. Haven't got that far yet but i will post pics of it later.
That sounds like a great idea PQ. Now I need to clean the heads. I hate the carbon buildup in there and seems so difficult to clean with all the curves, hard to scrape since the surfaces are not flat. I may not get too crazy with the heads and just focus on areas where the valves make contact.
Old 11-03-2012, 12:52 PM   #56
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Good stuff going on in here.. Great call on the 3600 stall.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
