Old 10-20-2012, 07:56 PM   #1
Indyblue98
2012 RS 2ss
Drives: 2012 2SS RS L99 WhippleCharged
WhippleCharged L99 Best and Worst runs from 10-19
Took the car out Friday night Low 60's temp 1500 Altitude.
Had 1 run where I actually got the launch right 1.88 60 ft
then started to loose it going into 3rd , decided to let out.
Best of the night was a 12.66 @ 117
with a pitiful 2.21 60Ft and hit the rev limiter on the 2-3 shift
Really wanted a low 12 @ 120 but I just wasn't able to get my act together.
If i could have held it straight on the 1.88 60 ft pass maybe a 12.2 ?
Car has Whipple at 8-9 lbs boost
1 7/8 headers iwth high flow cats
Cold Air intake
Tuned by Ted J
Corsa Axle Back
Stock tires at 27 PSI little burnput to clean them, just enough throttle/brake to take the slack out of the driveline maybe 1000 rpm, then roll into it.
TC and Stable Track off.
Didn't try with TC on.
Did a couple paddle shifts and a couple in M but auto shifting.
Biggest problem was trying to get enough throttle so it didn't shift premature, but still not spin.
Indyblue98 is offline   Reply With Quote
Old 10-20-2012, 09:48 PM   #2
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
I run a M6 and do a burnout with all tractions off, when I launch I go into competetive mode. Insurance policy....... I recommend it, seen a few people eat the wall. My 2 cents. Good luck next time!
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 10-20-2012, 11:14 PM   #3
Indyblue98
2012 RS 2ss
Prob good advice for someone at my skill level.
2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+KW V3 Coilovers
Old 10-21-2012, 01:53 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Thanks for posting, I've wondered what I'd run if I just added a blower.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
