HeadlightArmor
Old 10-21-2012, 06:50 PM   #1
black12lt
Drives: black 1lt 2012
Chordless Polisher
Im wondering if this exist? Im needing to invest in a polisher. Ive had my black car for a year now, its never been polished, waxed only once when I first got it, and my swirls are getting really bad. Problem is I dont have a garage, currently using my own soap, buckets, ect at local car wash..
black12lt is offline   Reply With Quote
Old 10-21-2012, 07:52 PM   #2
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
If they exist, you won't be able to find one that has the power/life that you would need to do real work. Stick with the cord.
ChadG is offline   Reply With Quote
Old 10-22-2012, 01:29 AM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
have to agree with this. The motor just demands too much energy.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-22-2012, 02:24 AM   #4
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
don't need a garage (if the weather is decent). Once the car is clean drive it home and polish it in your driveway (or street with a long extension cord)! You may need to do a quick No Rinse wash if anything got on it while driving home, then polish away.
IPT is offline   Reply With Quote
Old 10-22-2012, 08:00 AM   #5
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
There are a few out there and they just don't have the power one is looking for, I recommend getting a cord machine like the Porter Cable 7424XP Dual Action Polisher or the Griot's Garage 6" Random Orbital Polisher from the Autopia Car Care Store.. Also you can shop around for a used canopy and use it when detailing your ride.
Old 10-23-2012, 09:09 PM   #6
black12lt
Thanks for the advice guys. The main issue is no power source, I ,may have to result to the extension chord
Old 10-23-2012, 10:55 PM   #7
ChadG
ChadG's Avatar
Just make sure you spend money and buy a HEAVY GAUGE extension cord, your polisher manual should lay out what gauge is needed for what length - I know Junkman posted that info here a while back.
Old 10-23-2012, 11:21 PM   #8
ihaveacamaro
I like teeth.
Drives: #198
can't stress this enough!
Also, don't buy a bigger than 50 foot extension cord. I've heard of people having power drops that cause the machine to slow down if you do that.
Old 10-24-2012, 08:36 AM   #9
black12lt
Just make sure you spend money and buy a HEAVY GAUGE extension cord, your polisher manual should lay out what gauge is needed for what length - I know Junkman posted info here a while back.
thanks for the heads up I'll search for it! Should be in for good weather for a little while longer in NC
Old 10-25-2012, 09:21 AM   #10
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
Actually, you can go up to 100 feet according to Porter Cable. Where people run into problems is when they either buy the wrong gauge extension cord or they plug into a outlet that already has too much stuff on that circuit and they end up starving the polisher of current. The instructions that come with your PC lay out exactly what gauge to buy according to length.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 10-26-2012, 08:29 PM   #11
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Another option might be to try a power inverter. But it would probably mean running your car to avoid killing the battery. And that might introduce contamination.
Just throwing an idea out there. You'll have to do the research to see if it'd work.
Three of Swords is offline   Reply With Quote
