sjm autoprod
Old 12-31-2012, 04:05 PM   #1219
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
i haven't seen the instructions, but it looks like what's holding it by the wheel wells is just a flat-head screw. i can deal with a hole there if it means i'm not destroying my splitter every time i take the car out. i'm gonna get under the car here in a little while to install the skipshift eliminator and see about removing the splitter
OzzySS is offline   Reply With Quote
Old 12-31-2012, 04:14 PM   #1220
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
There are a bunch of rivets along the bottom edge as well as 3m tape.
tramtwo posted this on the go
tramtwo is offline   Reply With Quote
Old 12-31-2012, 04:43 PM   #1221
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I saw them do mine,yes there are some brackets, if you will,that are riveted on,then the splitter bolts to the car and attaches to the brackets.
cornerspeed92 is offline   Reply With Quote
Old 12-31-2012, 06:12 PM   #1222
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
To confuse the issue even more...
Old 12-31-2012, 06:53 PM   #1223
OzzySS
OzzySS's Avatar
Hmm yeah I wasn't prepared for rivet removal today. Might have to practice some different angles of attacking the driveway in the meantime.
Tried to plasti the slot again. Wasn't happy with the results so I peeled it. Might just go ahead and vinyl instead.
Just got the eliminator installed. They weren't joking about having to do it blind...yeesh.
Build thread linked in the pic...
Old 12-31-2012, 08:41 PM   #1224
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Did you disconnect the power to add the eliminator?
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 12-31-2012, 08:44 PM   #1225
CrystalRedTintcoat
Here is my vinyl hood. Washed this last week, added VRT which looked wet and streaky then it rained within hours. Car has been outside in rain and sun forna week while I was in Tahoe with family. Rain water dried on it. Doesn't look bad. Name:  ImageUploadedByTapatalk1357008212.994483.jpg
2013 1LE NPP GBE
Mods
Track Days
Old 12-31-2012, 08:45 PM   #1226
OzzySS
OzzySS's Avatar
no...didn't see anything saying to do that, or any obvious safety reason i should. did i miss something?
Old 12-31-2012, 08:46 PM   #1227
OzzySS
OzzySS's Avatar
tram are those wingnuts you're showing us?
Old 12-31-2012, 08:54 PM   #1228
scubadoo7
Airborne Recondo
scubadoo7's Avatar
Drives: Crystal Red 2SS 1LE
No need to disconnect power. I actually removed mine before car went back for repairs. Didn't want any reason to blame the mod for shifter failure. Btw, they told me today, that the shifter pin came out, and a new one will be there on Thursday. Sounds pretty lame that it was not secured well at the factory. Anyway, that's what warrantys are for right?
scubadoo7 is offline   Reply With Quote
Old 12-31-2012, 09:01 PM   #1229
OzzySS
OzzySS's Avatar
True enough. Shifter pin, huh...well, Thursday isn't bad for having a holiday between now and then. Still sucks that it happened at all tho
Old 12-31-2012, 09:30 PM   #1230
Zl1 #586
Zl1 #586's Avatar
Drives: 2016 Z06/07
Ozzy what part of your spitter is hitting left/right/center ?
We have a similar problem but there is a solution to protect it from damage ,you will still bottom out but the rub strip instead of the splitter.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=66451&dateline=135040 1562
Zl1 #586 is offline   Reply With Quote
Old 12-31-2012, 09:38 PM   #1231
OzzySS
OzzySS's Avatar
Interesting. Yeah, I'm rubbing the nose of it, pretty much right down the center
Old 12-31-2012, 09:53 PM   #1232
Zl1 #586
Zl1 #586's Avatar
Drives: 2016 Z06/07
The one in the pic is 3/16" aluminum but it could also be done in lexan/plexiglass lowes/home depot.is easy to fab.
Or make a pattern and take to an HVAC shop with sheet metal skills.
That just happens to be what we do but your a little out of our service area.
