Old 12-31-2012, 11:40 PM   #1233
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Originally Posted by OzzySS View Post
no...didn't see anything saying to do that, or any obvious safety reason i should. did i miss something?
My unit's instructions say to disconnect the battery. I don't want to. Since you didn't get shocked, I won't disconnect it either!
CrystalRedTintcoat is offline   Reply With Quote
Old 12-31-2012, 11:55 PM   #1234
newb
newb's Avatar
Drives: 2013 1LE
Originally Posted by Zl1 #586 View Post
Ozzy what part of your spitter is hitting left/right/center ?
We have a similar problem but there is a solution to protect it from damage ,you will still bottom out but the rub strip instead of the splitter.
That's a great idea. There was a ZL1 thread where someone made a full length one out of sheet metal. Looked pretty decent. I may have to do this just in case
Sent from a rainbow while riding a unicorn
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 01-01-2013, 12:01 AM   #1235
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
The one in the pic is 3/16" aluminum but it could also be done in lexan/plexiglass lowes/home depot.is easy to fab.
Or make a pattern and take to an HVAC shop with sheet metal skills.
That just happens to be what we do but your a little out of our service area.
Hmm would it be possible to rig one up that extends all the way to the edge? My damage is happening along the first inch or so. It looks like the part that's covered in the photo isn't what's getting torn up on mine, but I'm looking on my phone so it's a little hard to tell.
Build thread linked in the pic...
OzzySS is offline   Reply With Quote
Old 01-01-2013, 12:06 AM   #1236
OzzySS
OzzySS's Avatar
Yeah man, just go for it. There's really nothing around there that'll shock you, but you will likely be rubbing on your exhaust, so take that into consideration. Mine was hotter than i expected after only a few minutes of maneuvering the car in the garage. Also have a long flathead ready to help get it loose, I used one of my trim removal tools since my screwdrivers walked off again
Old 01-01-2013, 02:07 AM   #1237
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
tram are those wingnuts you're showing us?
Rivets that hold the splitter on....
tramtwo is offline   Reply With Quote
Old 01-01-2013, 07:29 AM   #1238
scubadoo7
Airborne Recondo
scubadoo7's Avatar
Drives: Crystal Red 2SS 1LE
Tools with legs...I know about that one!
scubadoo7 is offline   Reply With Quote
Old 01-01-2013, 10:25 AM   #1239
Zl1 #586
Zl1 #586's Avatar
Drives: 2016 Z06/07
Absolutely just make a pattern out of cardboard or whatever you have that will be easily transferable then just paint the leading edge to blend with the splitter
http://www.camaro5.com/forums/image.php?type=sigpic&userid=66451&dateline=135040 1562
Zl1 #586 is offline   Reply With Quote
Old 01-01-2013, 02:21 PM   #1240
CrystalRedTintcoat
Ozzy / Scuba: how did you guys get the factory connector off? Is the locking tab in the back? It feels like it but I don't have enough leverage with my hand to pry it open to pull the connector off. And I screwdriver doesn't fit back there. Advice?
2013 1LE NPP GBE
Mods
Track Days
Old 01-01-2013, 03:48 PM   #1241
OzzySS
OzzySS's Avatar
Attachment 457522
The tab was facing the rear of the car for me. I had good results using my angled trim tool, it was also handy for installation since it could push evenly. I'm not sure I can think of any other way to attack it. It's just a pain in the arse. Have you given the car any blood yet? I couldn't get mine installed until I cut my knuckle on the edge of the heat shielding
Old 01-01-2013, 04:29 PM   #1242
CrystalRedTintcoat
Four knuckle busters already! Thanks for the advice.
Trying to install my clutch reservoir now.
2013 1LE NPP GBE
Mods
Track Days
Old 01-01-2013, 05:32 PM   #1243
scubadoo7
Airborne Recondo
scubadoo7's Avatar
Seems Ozzy answered for ya, but yeah, it was really difficult getting fingers up there and visibility sucks. I too am a victim of the heat sheild, and I've got to do it again when my car comes home..lol
Old 01-01-2013, 05:54 PM   #1244
CrystalRedTintcoat
I think I'll take my friend's offer to use his LIFT. Just tried again. Skip Shifter has won. I've dicked around with this too long now.
EDIT: changed LIFE to LIFT. Damn iPhone!
2013 1LE NPP GBE
Mods
Track Days
Old 01-01-2013, 07:29 PM   #1245
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Yeah mine didn't have any instructions either about disconnecting the battery,i actually did it twice.The 1st run the skip shift led came on so figured i did it wrong,called phastek and they said it was fine,it was the eliminator fooling the computer,so did it again,and everything is just perfect.
cornerspeed92 is offline   Reply With Quote
Old 01-01-2013, 08:50 PM   #1246
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Does the light still come on on the dash once the eliminator is installed?
