BORLA
Old 10-22-2012, 10:49 AM   #1
strokerls1
Drives: 2015 Charger Hellcat
Going through the traps
I have a 2013 1SS 6spd. The only mod done is a CAI Intake and fuse pull on the dual mode mufflers. I have ran the car a few times at Atlanta Dragway with a best time of 12.8 at 111 with a 2.08 60ft. The problem is I hit the rev limiter at the top of 3rd right before I go through the traps. My time would be a few tenths quicker if this didnt happen. I tried to short shift a few gears to get the car into 4th but my time and mph suffer. The car definitely needs a gear. Does anyone else experience this?
The first video is me running the 12.8 and staying in 3rd. The second video is me shifting into 4th right before the traps and getting 13.0 at 110. My wife was recording and cut the videos short of the times. She said they wouldn't show clear. Ill post slips as soon as I get home.
strokerls1 is offline   Reply With Quote
Old 10-22-2012, 12:28 PM   #2
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
you can have the limiter tuned off or bumped up, but a gear change will cause an extra shift, which will also eat up the clock.
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 10-22-2012, 01:40 PM   #3
strokerls1
I see what you are saying, but I figure a gear change you give me more mph and help my time some. Does the LS3 continue to make power past the factory redline? It does feel like it falls off a little right before I hit the limiter. Maybe its just me though
Old 10-22-2012, 02:12 PM   #4
Sharkss
Drives: 2010 CGM 2ss/rs M6
you ran the same as i did with longtubes and a tune what gives??? i even ran the same mph...
Sharkss is offline   Reply With Quote
Old 10-22-2012, 02:27 PM   #5
h2oplay
Winners find a way
h2oplay's Avatar
That makes sense, I had the same issue with my v6, limited at the traps.
I went from a 3.27 to a 3.73, I'm not sure what gear you should go to from the 3.45.
Old 10-22-2012, 03:29 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Like right before, 50 feet something like that?
I don't think you'd pick really any ET grabbing 4th and MPH-wise maybe a little bit. It's counter-intuitive but do any of the MN6 guys ever just coast that little bit?
I'm modded and tuned and I tried higher shift points to finish the 1/4 in 3rd (A6) and my car didn't like it. I was well past where I make peak HP.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 10-22-2012, 08:29 PM   #7
h2oplay
Winners find a way
h2oplay's Avatar
I'm hitting 4th just passed the 1000, but that's another shift
Old 10-22-2012, 09:23 PM   #8
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Put on some taller rear tires...
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 10-22-2012, 10:23 PM   #9
Newold memories
Newold memories's Avatar
Drives: 2010 Chevrolet Camaro SS/RS
yeppp I run 40s on my 20 inch rims and dont quite top out third.....
2010 2SS/RS M6 LS3: K&N CAI, Eibach Pro Lowering Kit, Heritage Grill, Ceramic Tint, GM Performance Borla Exhaust, Hertz/Arc Audio Sound System, MPD1 Rear Spoiler, Rennen C-10 Wheels (20x9 w/ 275/40/20 front & 20x10.5 w/ 295/40/20 rear Continental DSW Extreme contact tires) Hurst Short Throw Shifter.
Visit us @ WWW.Facebook.com/SacramentoValleyCamaros
Newold memories is offline   Reply With Quote
Old 10-23-2012, 03:29 PM   #10
strokerls1
Driver mod . Jk the 2013 has a few nice upgrades that definitely help the car's performance over the '10-'12's. I had a 2012 and this car is definitely faster out of the box.
It will bounce the limiter about 150ft before the traps. If I grab 4th, the gear ratio changes drastically and I lose mph.
That is the factory tire size correct? 275/40/20?
Old 10-23-2012, 04:02 PM   #11
Sharkss
my 60ft was the same as his and so was the mph... so driver mod is good ill chalk it up to weather, it was 90% humidty when i ran last LOL and in the low 80s.
Old 10-23-2012, 05:34 PM   #12
jfayardiii
Drives: 2011 Silver 2SS/RS L99
what mods do the 2013s have that the 10-12s don't?
2011 2SS/RS L99
10.76@130.5 1.67 60'
LG headers and exhaust, 3200 Yank, EPS Cam, D1SC Procharger, all work performed by Blanchard Performance
jfayardiii is offline   Reply With Quote
Old 10-23-2012, 05:40 PM   #13
Pro Stock John
Writer
2013s can have that optional NPP exhaust, might be limited to just MN6 cars? The 2013s also all have the electric power steering stock.
PROJECT HEAVY CHEVY
Old 10-23-2012, 05:56 PM   #14
strokerls1
Correct...mine has both
