Emblempros
Old 10-22-2012, 07:39 PM   #1
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
M6 guys, what is the answer for us?
As I contemplate the performance future of my Camaro, I keep coming back to one problem.
The manual transmission on our 5th gen Camaros just is not up to the job.
Here is a fact for you, the stock tranny on these cars, is UNDER rated for the power output of the LLT.
All the M6 cars, except maybe the newest 2012s and 13s with the carbon syncros, ALL grind 1st to 2nd gear. If yours doesn't grind, you probably just cannot shift fast enough.
Any more power we make, generates more of a problem. The limit is right about what we can make with bolt ons.
All the m6 Forced Induction guys are having to replace their clutches. Clutch, I can understand, that is something that will need to be upgraded on every heavily modded car.
So what is the solution? A built tranny?
In addition, our gear ratios SUCK! 1st gear has a 4.48 ratio! The SS on the other hand has a 3.0! 4.48 is just too damn high! It makes the car a nightmare to launch and I have yet to see ANY M6 car pull better than a 2.0 60'. In fact, has any car done better than my 2.0? Which was on stock tires...
Help me out here people! How do we solve these problems?
DarkneSS is offline   Reply With Quote
Old 10-22-2012, 07:52 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I would like to know this as well......I've never grinded even when shifting fast but anyways
a built tranny would be my guess....
Lil' Nasty is offline   Reply With Quote
Old 10-22-2012, 08:04 PM   #3
camaro-21
camaro-21's Avatar
Drives: 2011 cyber grey metallic camaro v6
new clutch, carbon synchros, idealg master cylinder and remote clutch resevoir is wat im doing and ill update on how that helps
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
camaro-21 is offline   Reply With Quote
Old 10-22-2012, 08:05 PM   #4
DarkneSS
Definitely keep us posted. Where are you getting the synchros from?
Old 10-22-2012, 08:10 PM   #5
camaro-21
camaro-21's Avatar
i got them from the dealership. you just have to make sure they order the updated ones since they changed them earlier this year
Old 10-22-2012, 08:27 PM   #6
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Anyone consider an out right swap?
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 10-22-2012, 08:42 PM   #7
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Have you got part #'s? I've heard rumors, but not gonna believe it til I see it. Yes, please keep us posted.
Also, do you plan to have the dealer do the re-build or a local shop?
I've just added the IDEALG mod and the NH-SS fix for Hurst's shifter bushings. I want to re-bleed the master cylinder once more before I hit the 1-2 shift hard again- I figure we've got just a few of those grinds before the 2nd gear synchro is toast and nothing will fix it but a new one.
I'll hammer it by this weekend and report back.
Totally agree DarkneSS, the tranny has been the only part of this car I'm beginning to think cannot be fixed to my satisfaction. It pisses me off just about every time I drive.
I'm planning to stay N/A, so output is not one of my issues- but I was expecting to cam, etc.. But if I can't enjoy shifting, well what's the point?!
Old 10-22-2012, 08:56 PM   #8
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Part numbers if you can get them in the process of building mine so far spec clutch and flywheel.
Sent from my iPad using Tapatalk HD
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-22-2012, 09:00 PM   #9
camaro-21
camaro-21's Avatar
i got the box at home so ill give you guys the part number
Old 10-22-2012, 10:36 PM   #10
DarkneSS
Please please please post paper work! Block out your personal info we just want to data.
I would but what the hell could we swap for? The SS M6 tranny won't fit right?
Crazy but it seems like a reasonable option would be to swap out for the A6 tranny from the V6 cars, reattain the rear end off the manual, and get the auto tranny completely built to be bullet proof for FI power levels.
That is what I'm worried about and I told the tech that works on my car at my dealer. He just put his hands up in a shrugging action and said that on the bright side, if it does break, just bring it in and since it is under warranty they will fix it.
After seeing our boy run a 12.1 in the V6 1/4 thread I really want to go FI but the tranny is stopping me. I'm not spending a cent more on performance until I feel comfortable about this tranny.
Flywheel and clutch are great but they don't solve the tranny problem unfortunately.
Old 10-23-2012, 01:26 AM   #11
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
i would like to know what we can do also, i have never felt an actual grind going into second, but i know that it just doesnt feel good going into second at higher rpms. my problem i have is sometimes it just wont go into first. its like it goes a little bit in but not all the way. so i put it back to netural and try again, and most time it takes more then 3 tries to get it into 1st or i say screw it and throw it into second to take off in. If im not in a hurry cause im at a light when i put it into netural i pump the clutch a few times, and it does seem to help, or maybe its just a coincidence or just needed a break before i try again lol i dont know. its done that i think most the time ive owned this car, so it may be a clutch issue more then a tranny. either way the tranny for sure is the weak link here for manuals. i mean freaking toyotas use the ay6 lol i think with all the factory goodies we got like IRS, and LSD they would give us a better tranny lol.
'11CamaroLS is offline   Reply With Quote
Old 10-23-2012, 01:31 AM   #12
midnighter
Drives: nothing
I've never ground 2nd gear but I did bake some clutch learning to power brake/ peel out in a manual for the first time in this car.
Old 10-23-2012, 06:54 AM   #13
twmotox
twmotox's Avatar
Drives: 2013 Camaro 1LT RS
I have a 2013 and its much smoother than the 350z i had before
Loyalty above all else except honor!
twmotox is offline   Reply With Quote
Old 10-23-2012, 10:35 AM   #14
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I did the ideal slave, gto res and changed the trans lube to amsoil, it's much better than before, a very rare crunch at the track, but you still can't shift these cars fast..... I shift around 64-6500 now since that's where peak torque drops off.
I'm toying with the idea of having a plate made so I can use a torqueflight 3 speed for the track.
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
