Old 10-24-2012, 09:23 AM   #29
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Originally Posted by Yellow_Glide View Post
If the input shafts are the same thn it's a fairly straight forward deal.
Originally Posted by h2oplay View Post
Jay Leno's v6 turbo has a tremec, not sure how they pulled it off.
Let us look into this.
A ss tranny will carbon synchros won't be bullet proof but it should handle a boosted LLT just fine. We M6 guys already have the SS rear so we'd be good to go after an upgraded clutch.
I'd expect the SS trans to hold up longer than the LLT under boost.
DarkneSS is offline   Reply With Quote
Old 10-24-2012, 11:07 AM   #30
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Very true. If the tremec would sustain 600 crank hp, that should suffice until the stroker crank is available.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 10-24-2012, 12:05 PM   #31
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I like the way you're thinking. (Does anybody else remember the old joke that ends with that as a punchline?).
Old 10-24-2012, 01:06 PM   #32
vinman
The BBOMG fill-in husband
vinman's Avatar
Only the M6/RS have the SS rear and half shafts
UPSTATE C5 MEMBER
Old 10-24-2012, 01:27 PM   #33
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
with enough money almost anything is possible lol
'11CamaroLS is offline   Reply With Quote
Old 10-24-2012, 04:08 PM   #34
DarkneSS
Really? What do you get if you ordered an M6 with no RS? That is bizarre...
And not my problem! LOL
Old 10-24-2012, 04:31 PM   #35
bcperry
Engineer in Training
bcperry's Avatar
Drives: IBM 2010 Camaro LS
Are you sure? I'm pretty sure my car is a LSD.
K&N Aircharger CAI, BBK LT's, VMAX black ICE, Trifecta tuned
bcperry is offline   Reply With Quote
Old 10-24-2012, 04:36 PM   #36
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
It does for 2010-11 for sure, not sure what they've done after
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 10-24-2012, 05:26 PM   #37
Ventmaster
Ventmaster's Avatar
Quick update on the IDEALG modified clutch mastercylinder- I think it works!
I'm running the Hurst aftermarket shifter (I think about the shortest throw out there- but not necessarily the best one), with the regular DOT#3 brake fluid in the OE hydraulic lines and right now I've got the OE gear oil in the trans. So the new mastercylinder gets the credit. The only other recent change was the NH-SS bushing replacement- which I also recommend because it really tightens up the shift pattern on the Hurst, but I doubt it impacts the 1-2 shift that much.
Today I re-bled it (just to be sure) changed the engine oil and took her out revved the shite out of it! Tried to make it grind- shifted beyond redline and... no noise, no crunch, no nothing.
Now it's still a balky, notchy little PIA tranny. But if I can bang a clean 1-2 shift and squall those back tires for a looong time every now and again, well I might keep it bit longer.
I'll still be watching for an easy swap for the Tremec out of the 1LE say?
Old 10-24-2012, 07:34 PM   #38
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
I rather replace my tranny with a home built tranny made out of butter and wood. It would definitly hold up better then out POS tranny. The fn grinds make you look like an amateur in front of people when it's really this crappy tranny. Guess it's evident how much I hate this tranny. Oh and it's soo damn notchy, doesn't want to go into first once in a while. Can't wait to replace it completely. Thinking Tr6060
CAMARO
Old 10-24-2012, 08:10 PM   #39
Tulkas
Drives: Holden ve sv6 2007 manual
Has anyone attempted to try fitting a tr6060 onto the LLT engine?
Or if they tried and it doesn't fit?
Tulkas is offline   Reply With Quote
Old 10-24-2012, 09:08 PM   #40
Yellow_Glide
I sent a PM to one of the vendors in the Vendor Tranny section - hopefully will at least start the conversation if not get some needed info. I'll post as soon as I have something.
Old 10-24-2012, 09:22 PM   #41
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
I was hoping that the new Tremec (TR3060) developed for the new Caddy ATS would work since the ATS is also going to offer the 3.6, but the Motor Trend review said it wasn't that great of a tranny.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 10-24-2012, 10:49 PM   #42
KMPrenger
KMPrenger's Avatar
Yeah the Jay Leno had the Tremec....I'm sure you can google or youtube the Jay Leno Twin Turbo V6 and find the video. It mentions it, but don't think it gives much in the way of details.
Just read on motortrend that GM is stopping production on all the manual ATS at the moment to hopefully put a fix to that.....so it could still be a possibility!
