Caryle Racing
Old 10-25-2012, 12:26 PM   #43
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
You know, Jay Leno seems to be a real car guy. So what if we all wrote to him/his show explaining our problem and that we simply want to know what tranny he has on his TTV6 car? If he is a real car guy I see no reason why he wouldn't give us some info.
I am worried that it is not cheap.
DarkneSS is offline   Reply With Quote
Old 10-25-2012, 12:50 PM   #44
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Summit has built tr6060s for 2800$ outright. Site had the input shaft spec of 1 1/8" 26 spline. If we can get the input shaft size and some pics of the bell housing might be able to do some measurements.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 10-25-2012, 12:53 PM   #45
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
you mean what tranny or how they got it to work? cause in the video he says tremec 6060. Good idea of asking how they got it to work though...
'11CamaroLS is offline   Reply With Quote
Old 10-25-2012, 01:35 PM   #46
DarkneSS
Yeah the tranny my bad I never watched the video lol. He still might explain how it was done though...worth a try?
Old 10-25-2012, 01:52 PM   #47
'11CamaroLS
i think so, if i remember when i get off work i'll try an email
Old 10-25-2012, 01:54 PM   #48
KMPrenger
KMPrenger's Avatar
Might be worth a try, but I doubt he knows how it was really done. Yeah it is the "Jay Leno TTV6 Camaro" but I doubt he had so much input with the car the he knows specically how they got the tremec to work with the V6.
He does not have the car in his collection...it is GM owned and hard to say what GM is doing with it at this point, but it was really nice to see that well after the SEMA show where it debuted, they were still tweaking it and testing with it.
He is definitely a car guy.
Old 10-25-2012, 03:31 PM   #49
Goo
Goo's Avatar
Drives: Cayman S
Originally Posted by KMPrenger View Post
Just read on motortrend that GM is stopping production on all the manual ATS at the moment to hopefully put a fix to that.....so it could still be a possibility!
Test rode the Auto AWD ATS... Too bad we couldn't get the AWD in our Camaro...
They had NO standard on the lot any where around here...
Goo is offline   Reply With Quote
Old 10-25-2012, 04:48 PM   #50
jjjaroscak
jjjaroscak's Avatar
Drives: Cyber Gray 2011 2LT Camaro
Originally Posted by h2oplay View Post
Sounds like the ideal g slave is for you, not enough fluid for proper disengagement. get the gto res too, I think it was about 15 bucks.
I've been away from the forums for a while. What is the ideal g slave and gto res?
jjjaroscak is offline   Reply With Quote
Old 10-25-2012, 05:28 PM   #51
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Look at this post in the V8 and V6 Transmission forum- Poll: Project clutch master cylinder/second gear grind ( 1 2 3 ... Last Page)
IDEALG
The 5th Gen's have a mastercylinder (not really a slave) under the clutch pedal. This member has modified it to provide more volume when depressed and it appears to alleviate the 1-2 shift grind.
Some people are also separating the reservoir for the hydraulics (brakes and clutch) to help keep the fluid cleaner, etc...
I just changed out the m/c and I'm really excited about the improved shifting!!
Old 11-02-2012, 12:41 AM   #52
camaro-21
camaro-21's Avatar
Drives: 2011 cyber grey metallic camaro v6
here are the part numbers for the carbon synchros
-1st and 2nd gear 19260793
-3rd and 4th gear 19259367
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
camaro-21 is offline   Reply With Quote
Old 11-02-2012, 12:58 PM   #53
Yellow_Glide
Thanks for posting!!
Old 11-03-2012, 01:31 PM   #54
Ventmaster
Ventmaster's Avatar
+1
Thank you much!
Old 11-03-2012, 04:46 PM   #55
Yellow_Glide
Checked gmpartshouse about $326 for both.
Old 11-03-2012, 06:53 PM   #56
Ventmaster
Ventmaster's Avatar
And then there is the cost of installation... .
But I'm sure this will be in my tran's future at some point.
In the meantime- don't over look the IDEALG modified clutch master cylinder. That combined with clean fluid (surprisingly dirty after just 9K miles), has really improved (OK- done away with) my fast-shift grind so far.
Definitely worth doing IMHO.
