Old 10-23-2012, 12:13 PM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Apex Scoop and Washer Bottle Install (or most any other brand)
I took alot of photos as I installed my scoop and washer bottle relo kit. This is not a full fledged do it yourself, but I hope the photos help someone along the way
The instructions provided make complete sense when you are done, but it is easy to misunderstand a few things and confuse correct orientation when just reading words. For example it is easy to read into and think that the new horn bolt provided is for bolting on the scoop under the head of the bolt. NOT, it creates a stud on the backside because it is longer...and you simple put a nut on the stud. The instructions clearly say "replace the horn bolt"
Start by making things simple. Take the wheel, fenderliner and your existing CAI out.
Here's a quick list of tools
-A couple screwdrivers for clamps and CAI lid
-Torx bit #20? I forget, for the fender liner
-trim removal tool for scrivets
-10MM open wrench for the CAI itself and for the horn bolt
-7/16 wrench and or sockets for the 4 new bottle bolts and filler neck
-13MM sockets and/or wrench for the OEM bottle bolts
-Dremel tool or some sort of nippers to cut the plastic grille fascia and the nib off of the washer pump motor
-Scissors or knife to cut tubing to length
Here are the photos
f5journal is offline   Reply With Quote
Old 10-23-2012, 12:16 PM   #2
f5journal
f5journal's Avatar
Continued
At this point everything is removed, and the opening in the grille is cut. Now we install
Old 10-23-2012, 12:18 PM   #3
f5journal
f5journal's Avatar
More
Old 10-23-2012, 12:37 PM   #4
Bobsled
Bobsled's Avatar
Drives: 2012 Victory Red 1LT/RS
Nice pictorial. Going to install mine this weekend and refer to your pics if I get into trouble. How much work is it to take the plastic wheel liner off (just wondering, I know it has to come off)?
Thanks.
Bobsled is offline   Reply With Quote
Old 10-23-2012, 12:40 PM   #5
f5journal
f5journal's Avatar
Pretty easy with the right tools. You need a Torx bit (preferably a screwdriver type one. There are 3 at the lower front edge and 2 at then lower rear edge. The all you do is remove 5-6 "scrivets". You have to pull the center button out of those and then remove the push pin type deal. Those are best removed with the right tool, but a screwdriver or butter knife work OK. You can see one installed scrivet in my last picture.
Old 10-23-2012, 01:16 PM   #6
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I suggest buying one, it saves the scrivets from being ruined.
http://www.oreillyauto.com/site/c/de...d=trim+removal
Did the APEX washer bottle come with the bolts to secure the filler part to the CAI box?
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 10-23-2012, 01:23 PM   #7
f5journal
f5journal's Avatar
Agree on buying the right tool. I got the 2-handle squeeze ones
The kit comes with the four bolts for the bottle and two for the filler neck. I used all the washers provided on the bottle and had to round up some for the filler neck
I've edited my original post to add some of the tools needed that I recall.
Here's the trim tool I bought at Advance Auto Parts. They have the one in the link above also
Old 10-23-2012, 01:47 PM   #8
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
I see the hose go up then down through the hole. Will that cause any back up when filling with the liquid? or liquid left in the tube?
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 10-23-2012, 01:52 PM   #9
f5journal
f5journal's Avatar
All is good as long as it goes up hill to the filler. It's routed along that bend in the CAI shroud to the filler on the other side there
Old 10-27-2012, 01:43 AM   #10
Bobsled
Bobsled's Avatar
I ended up buying some of these LINKY. They also had the squeeze type. I install my stuff tomorrow.
Old 10-29-2012, 04:18 AM   #11
Wooden Heart
Wooden Heart's Avatar
Drives: 2012 Camaro LT
Did you trim your clear hose any?
Wooden Heart is offline   Reply With Quote
Old 10-30-2012, 11:34 AM   #12
f5journal
f5journal's Avatar
I cut at least a 1/3 off of it
Old 10-30-2012, 12:56 PM   #13
Ehmsea
Ehmsea's Avatar
Drives: 2013 2SS RS Hurst NPP
Nice group of pictures on this one. Really helps me visualize what is involved with this mod. Thanks, I'll bookmark.
No Worries
CAI Intake w/washer relocation and race scoop
Ported Throttle Body (Polished)
Kooks LT stepped headers 1-3/4 to 1-7/8
High Flow Cats
Livernois Motorsports Stage 2c Cam Package
https://www.youtube.com/watch?v=AKXyCyBh9BU
Hill Start Assist Delete
Ehmsea is offline   Reply With Quote
Old 10-30-2012, 01:18 PM   #14
Bobsled
Bobsled's Avatar
Yeah, he did do I good job of photo documenting the procedure.
One thing I did that most people don't bother with is to remove the old neg. battery post that is now useless after a CAI install. Gave me more room to work with.
