Old 10-23-2012, 11:40 AM   #1
npd337
Drives: 2013 Ash Zl1
Anybody have a diy to SAFELY debadge
Looking for help on how to safely remove camaro badge on fenders. Thanks
npd337 is offline   Reply With Quote
Old 10-23-2012, 11:46 AM   #2
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
A little heat and some fishing line...
tramtwo is offline   Reply With Quote
Old 10-23-2012, 11:55 AM   #3
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
Heat for sure, they come off super easy with some heat. If there is any residue left, get some "Pre Cleaner" or "Wax and Grease Remover" and use it with a microfiber towel. The residue will come off super easy.
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Sickness91Z28 is offline   Reply With Quote
Old 10-23-2012, 12:05 PM   #4
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
I took the plastic/chrome letters off the sides of mine. First used fishing line and a hair dryer. Read that or saw that somewhere. What happens when you do it that way is a lot of the adhesive stays on the car. Then you waste ten minutes rubbing off the glue. So I say DO NOT USE FISHING LINE. Instead, get a hair dryer on high heat and at full blast start heating up the edge of one letter. After a minute take something plastic, credit card, spoon, whatever as long as it can't scratch the paint, and pry up the edge. You will see the adhesive pull off the car and stick to the letter. Keep the hair dryer on and direct it right where you are slowly lifting up. This way no adhesive is left on the car. It all comes off in one shot. Super easy. About 15 minutes and you'll have both sides done.
The look, I think, is way better. Super easy, start at any one spot, keep the heat blowing on it and all the adhesive comes off!
Normagene is offline   Reply With Quote
Old 10-23-2012, 01:52 PM   #5
RobZL1580
Drives: 2013 Camaro ZL1
Are you going to put anything else on the front fender or leave it bare? I think it would look good for the fenders to say ZL1 with Camaro removed and the hood to say something like 6.2 Supercharged and remove the hood ZL1 emblems.
Any thoughts?
RobZL1580 is offline   Reply With Quote
Old 10-23-2012, 02:07 PM   #6
npd337
No I kind of like the bare look. Plus every time I wash the car I come close to ripping off a letter by accident.
Old 10-23-2012, 03:30 PM   #7
ZL1LEGEND
ZL1 - The Legend Returns!
ZL1LEGEND's Avatar
Drives: 2013 ZL1 Camaro
Use dental floss instead of fishing line. Safer for the paint. You can also buy a rubber wheel and attach it to a drill to rub off the tape. IMO
ZL1LEGEND is offline   Reply With Quote
Old 10-23-2012, 03:38 PM   #8
CamaroRBT
Who's Laughing Now?
CamaroRBT's Avatar
Drives: 2011 Camaro 1SS RS LS3 Summit White
No heat.... 40lb test fishing line and goo gone.
CamaroRBT is offline   Reply With Quote
Old 10-23-2012, 04:22 PM   #9
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
GOO GONE/WD40 and Dental Floss easy peasy
ToolFan66 is offline   Reply With Quote
Old 10-23-2012, 04:30 PM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Debadging makes the car look fat like a Charger.
But like the others said, some vinyl fishing line and heat. Then some Goo Off will remove the residue safely.
Old 10-23-2012, 11:08 PM   #11
rzrbck_zl1
rzrbck_zl1's Avatar
Drives: '13 ZL1 CRT #702; '05 Hemi Ram
I've removed lots of badges over the years using just dental floss then a bit of WD-40 to remove any residual glue.
rzrbck_zl1 is offline   Reply With Quote
Old 10-23-2012, 11:48 PM   #12
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Do these badges make my ass look fat?
Old 10-24-2012, 08:13 AM   #13
Speedforhire
Speedforhire's Avatar
Drives: 2013 GRAND SPORT (aka: EREBUS)
I've tried the fishing line on the rear badge and it stops about 1/2" in from the corner. Is the rear badge studded? Any tips to get it off?
Oh, BTW! NORMAGENE your car is the BOMB! I think AGM is my favorite color on this car.
Speedforhire is offline   Reply With Quote
Old 10-24-2012, 10:31 AM   #14
Normagene
Normagene's Avatar
No studs, just glue. Use the hairdryer on high heat full blower power. Forget the fishing line or dental floss. Gently pry up just a hair then direct the heat for a minute right where you are starting to lift and slowly pull up with the heat hitting the gap. As you pull up slowly you will see the adhesive lift right off the car. If you pull too fast you will leave some of the adhesive on the car and then you waste time cleaning it up afterwards. Slowly with heat and zero adhesive is left behind. Took about 15 minutes to do the camaro letters on both sides. The rear bowtie took 3 minutes tops. Then just a dozen coats of wax and you're all set.
I replaced it with the billet black aluminum bowtie, peel off the paper and stick in place. If you want it to be placed exactly where the original one was, I recommend using painters tape. Four small pieces, two inches long or so for each piece and place them around the left/right/top/bottom edges. Then remove the gold one like above and now you have your tape markers exactly right to align the replacement.
