Caryle Racing
Old 10-23-2012, 04:26 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Will a Metco driveshaft loop fit a ZL1 automatic transmission?
Just wanted to see if one of the bolt in Metco driveshaft loops fits the ZL1 automatic. Thanks.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-24-2012, 09:46 PM   #2
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
X2
Trackman is offline   Reply With Quote
Old 10-24-2012, 10:07 PM   #3
Stephen12ZL1
Drives: '17 ZL1 A10
called Metco and they did not know but they did ask me to send them a pic of the tranny crossmember. I should shoot them a link of the car underside video.
Old 11-25-2012, 03:33 AM   #4
thespymaster
thespymaster's Avatar
Lets us ALL know what you find out...
So far 2 of 3 tracks I went to, look / demand the loop to run faster than 14
Old 11-25-2012, 09:05 AM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
I see there are other brands that claim to be bolt on also. I did not contact Lingenfelter as they probably know what fits.
Old 12-13-2012, 01:33 PM   #6
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Should bolt right on I have them in stock.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-07-2013, 06:41 PM   #7
Trackman
Trackman's Avatar
Response from Metco:
"Hey Dan…
We have not yet confirmed the fitment of our loop on the ZL1 with the automatic transmission. Our understanding is that the loop will bolt to your car’s crossmember just like it does in the L99 Camaro application, but the added length of your 6L90E transmission may affect the position of the hoop relative to the front u-joint."
I figured with a Jannetty "should bolt on" and a Metco "Our understanding" chances are it would so I went ahead and purchased it for the automatic.
No such luck. The "T" brackets do not fit properly in the aluminum transmission crossmember. The ZL1 must use a different crossmember. The main bracket also hits the exhaust. New brackets will have to be built to have any chance of it working.
Old 03-07-2013, 07:21 PM   #8
Trackman
Trackman's Avatar
The brackets are suppose to mount square but they interfere with the aluminum crossmember. I will built a couple of brackets that will attach the 3 pieces together as seen in pic 3. This will also raise the "Metco" logo bracket just enough that it "should" miss the exhaust.
Old 03-07-2013, 10:30 PM   #9
Stephen12ZL1
Drives: '17 ZL1 A10
I suspected there would be an interference. Thanks for the post
Old 03-08-2013, 09:44 AM   #10
JANNETTYRACING
"Hey Dan…
No such such luck. The "T" brackets do not fit properly in the aluminum transmission crossmember. The ZL1 must use a different crossmember. The main bracket also hits the exhaust. New brackets will have to be built to have any chance of it working.
I apologize.
With all the crossing of common parts from the Camaro and I looked at mine quick, it looked to be the same, I really didn't think there was a difference.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-08-2013, 10:10 AM   #11
Trackman
Trackman's Avatar
I apologize.
No apology needed. You said should not would.
I'll weld a couple of ears on the Metco bracket to extend to my new mounting points and I'll be good to go.
Some internet sellers are saying this will fit. It will not on the 6l90.
Old 03-18-2013, 10:03 PM   #12
Trackman
Trackman's Avatar
Here is the bracket I designed and had laser cut to make the Metco loop work with the 6L90 transmission. I had to remove a couple of washers that were shown in a picture to get proper clearance for final assembly. The loop is only 1/8 of an inch away from the exhaust but does clear. Ultimately Metco should build a new bracket system for the ZL1 but I suspect with only a handful of ZL1's wanting a drive shaft safety loop that there will not be enough call to build one specific for it.
Old 03-19-2013, 09:31 AM   #13
JANNETTYRACING
Very Nice Workmanship.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
