Caryle Racing
Old 10-23-2012, 04:38 PM   #1
ZL1LEGEND
ZL1 - The Legend Returns!
ZL1LEGEND's Avatar
Drives: 2013 ZL1 Camaro
ZR1 Engine and the ZL1 Engine
So what's the difference? Is the same LSA used in CTsV ZL1 AND ZR1?
ZL1LEGEND is offline   Reply With Quote
Old 10-23-2012, 04:47 PM   #2
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Zr1 has a 2.3L blower. Zl1 and ctsv have 1.9L
Zr1 has a different cam, among a few other internal differences.
KKreme15 is offline   Reply With Quote
Old 10-23-2012, 04:48 PM   #3
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
ZR1 has a LS9 which has a 2.3 Eaton blower.
Taser Deployed is offline   Reply With Quote
Old 10-23-2012, 05:00 PM   #4
speedmon
Drives: C6 Z06
2.3L Blower vs. 1.9L Blower and Block and heads are beefier.
And the ZR1 Engine is about $10K More.
ZR1
  • Engine Type: LS Series Gen IV Small-Block V-8
  • Displacement (cu in): 376 cu in (6.2L)
  • Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92mm)
  • Block: Cast-aluminum with 6 bolt,
  • cross-bolted main caps
  • Crankshaft (P/N 12598610): Forged Steel
  • Connecting Rods (P/N 12624231): Forged titanium
  • Pistons (P/N 12598634): Forged aluminum
  • Camshaft Type (P/N 12605527): Hydraulic roller
  • Valve Lift (in): .562” intake / .558” exhaust
  • Camshaft Duration (@.050 in): 211° intake / 230° exhaust
  • Cylinder Heads (P/N 12621774): Aluminum L92 style ports;
  • as cast with 68cc chambers
  • Valve Size (in): 2.16 intake / 1.59 exhaust
  • Compression Ratio: 9.1:1
  • Rocker Arms (P/N 12569167 int): Investment-cast, roller trunnion
  • Rocker Arms (P/N 10214664 exh): Investment-cast, roller trunnion
  • Rocker Arm Ratio: 1.7:1
  • Recommended Fuel: 92 octane
  • Maximum Recommended rpm: 6600
  • Reluctor Wheel: 58X
  • Balanced: Internal
LSA Motor
  • Block (P/N 12627939): Cast-aluminum with 6 bolt,
  • Crankshaft (P/N 12603616): Forged Steel
  • Connecting Rods (P/N 12604857): Powdered metal
  • Pistons (P/N 12625119: Hypereutectic aluminum
  • Camshaft Type (P/N 12605220): Hydraulic roller
  • Valve Lift (in): .480” intake / .480” exhaust
  • Camshaft Duration (@.050 in): 198° intake / 216° exhaust
  • Cylinder Heads (P/N 12604860): Aluminum L92 style port;
speedmon is offline   Reply With Quote
Old 10-23-2012, 05:31 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Hmm... Max' RPMs don't look right for LSA... I think it's something like 6200...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-23-2012, 05:33 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe LS9 also has Ti intake and hollow-sodium-filled exhaust valves.
Old 10-23-2012, 07:48 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Great post, Speedmon....and I agree with your points, as well Radz.
The differences are in strength of materials and hp/tq...not the design. So it's easy to confuse the two when just casually talking about it.
Old 10-23-2012, 09:04 PM   #8
Taser Deployed
Just playing a numbers game if GM would have put the LS9 in the ZL1 we would be looking at a 70k Camaro.
Old 10-23-2012, 11:41 PM   #9
ZL1LEGEND
ZL1LEGEND's Avatar
Good stuff. Thanks for clarification. This settled a long time father son debate. Hahah
Old 10-26-2012, 12:28 PM   #10
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
And the shelby wouldnt be beating up stock zl-1's
joes407 is offline   Reply With Quote
Old 10-26-2012, 12:35 PM   #11
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Itl be a lot closer when gm releases the stage 2 upgrade. From what I heard from the service manager at my dealer he said he was just in a meeting where they were talking about and it should be out by spring and be under 800 bucks.
ace32x is offline   Reply With Quote
Old 10-26-2012, 12:37 PM   #12
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
What are the differences between the ZL1 and the LS3 aside from the obvious Supercharger? LoL
Sent from my friggin Droid by two thumbs using Tapatalk 2 or whatever the ish it's called....
Firefighter is offline   Reply With Quote
Old 10-26-2012, 01:47 PM   #13
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
Really? Or are you...
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, BLACKED OUT BOWTIES, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 10-26-2012, 01:53 PM   #14
ace32x
ace32x's Avatar
Drives: 2013 ZL1
I'm being serious just talked to him yesterday morning.
