Cold Air Inductions
Old 11-06-2012, 01:17 PM   #15
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Originally Posted by soloknight6 View Post
Still waiting to find out if there is somewhere in the door itself we can tap in to, and would like pictures of wiring. Dont want to tap in to the wrong wire now...
As the instructions above indicate you do not tap power inside of the door. You use the parking light wire from the BCM for parking light power.
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 11-06-2012, 06:00 PM   #16
AACstyle
AACstyle's Avatar
Originally Posted by gbmike View Post
I just sent an e-mail to Jonathan @ AAC, we have 3 separate posts that I know of
DIY: Installing ORACLE Concept LED Sidemirrors from AAC :
http://www.camaro5.com/forums/showth...02#post5779702
AAC Concept Mirrors - HELP PLS! (me)
http://www.camaro5.com/forums/showthread.php?t=258921
How to run wires into the door
http://www.camaro5.com/forums/showthread.php?t=155660
hopefully they will create a new (detailed) one that will help their customers ...
We plan on posting pictures as soon as we get an in-house installation (customer pushed back the appointment then we had to leave for SEMA).
In the meantime what exactly do you need information about? We would be happy to help
www.AACstyle.com
Old 11-06-2012, 06:27 PM   #17
gbmike
gbmike's Avatar
Drives: Had 3rd 5th Gen: 2014 1SS/1LE
Ah ok thnx, well sorry to force the issue then. For me I have some info from Ofer about connections but still need info on where the wiring loom comes out on the other side of the a pillar. Do we remove the wheel liner to get access, and assume that using the door to body wiring is the only option to get to the front turn signals?
gbmike is offline   Reply With Quote
Old 11-07-2012, 08:03 PM   #18
AACstyle
AACstyle's Avatar
When you feed the wires through the door loom they end up in the driver footwell near the fuse box
www.AACstyle.com
Old 11-07-2012, 08:05 PM   #19
AACstyle
AACstyle's Avatar
While we were at SEMA we shot a quick video overview of the sidemirrors.
Check it out:
www.AACstyle.com
Old 11-07-2012, 08:13 PM   #20
OVERPAR73
2013 CRT ZL1 convertible
OVERPAR73's Avatar
Drives: 2013 ZL1 vert
Now if we had step-by-step instructions on how to wire these up to include pictures for those of us that are beginners in wiring.
OVERPAR73 is offline   Reply With Quote
Old 11-07-2012, 09:11 PM   #21
gbmike
gbmike's Avatar
eeeeuuueww .... got it (I think - see pic below). So I know you are trying to help but I feel like I (we) are getting bits of answers every time. So if that IS the correct loom (in the pic) then how do we get from the footwell into the engine bay??
BTW, the video is nice but again I hear "plug and play", well apparently that may be the case unless you order the LEDs like I'm sure a lot of us did, there is no way this is plug and play.... or before shipping you really should have given a full set of instructions. As "Overpar73" mentions, some of us are nowhere near the level of other guys on this forum as far as wiring or mechanical or whatever, so by the fact you mention plug and play when ordering I thought all I had to do was literally plug it in, that is not true at all and is now causing "pain" for not only us, but AAC as well having to attempt answering all these questions ....it's extremely frustrating b/c we want to get these mirrors on !! ... ok, I'm done
Wait I lied, 2 more things I thought of recently, are the LEDs legal if they are on all the time (I'm in PA), I assume so, they are also "side markers" right? and can we connect them as side markers and hook into the turn signals as well?
ok, done now ...
Old 11-08-2012, 09:47 AM   #22
OVERPAR73
OVERPAR73's Avatar
Plug and play my ass! Sorry but there is allot of additional wiring any I'm no expert at this, I hope I can get them installed OK, that is if I ever receive them!!!
Old 11-08-2012, 09:59 AM   #23
AACstyle
AACstyle's Avatar
There is a grommet that the main engine harness goes through in that same area that leads into the engine bay. If you look under the hood and follow the harness from the driver fender through the firewall its right there.
Yes, correct they are a marker light and fall into compliance with FMVSS and NHTSA regulation.
In the video we state that the factory controls are plug and play, the LEDs you need to wire up. Its not "allot" of additional wiring, its a simple 2 wire connection (when it comes to 12V it LITERALLY does not get any easier than a + and - connection) its really getting made out to be more trouble than it is.
www.AACstyle.com
Old 11-08-2012, 11:31 AM   #24
tmac1granger33
NM HT5
tmac1granger33's Avatar
Drives: COTW 3/5/12
lol this made me laugh thought i was rushed out to get em, ill be keeping an eye on this tread hope to do the install mid next week
Status 22" Staggered painted wheels/Eibach 1" Pro Kit Lowering Springs/Heritage Grille/Razzi Ground Effects Kit/RK Sports 3 piece Spoiler/DT Shortie Headers/Injen CAI/MRT 1.0 /Resonator Delete/Oracle Dual Red-white halos/Knight Rider grill Light/Sparks RS emblem/LED Sidemarkers/Red interior lighting/Gm fuel door/Halo Foglights/Trifecta Tune/IGGEE Seat covers/ Sinister Hood,VMAX throttle body/VMAX Black Iceolator/Technostalgia LED Taillights/3dCarbon Fender Vents/AAC Concept mirrors/zl1 bumper/AAC Plasma's/Scosche kit
WL-BMR Strut Bar/Custom rear vents
tmac1granger33 is offline   Reply With Quote
Old 11-08-2012, 11:33 AM   #25
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
hole in firewall
ok guys, doing 2 installs tomorrow, but working on some other lighting today.
there is a hole in the firewall that has a rubber plug, look at the brake reservoir, just to the right of it, get your face low and next to the reservoir, look to the right of the reservoir, at the firewall, you will see a screw sticking out of the firewall, to the right of it is the rubber plug, push a long screwdriver through it and you should see it inside the car, might have to move carpet and padding to the top
sorry pics are rotated to the right:(, so the top of the pic is to the right
lupe
overhaulengines is online now   Reply With Quote
Old 11-08-2012, 11:48 AM   #26
AACstyle
AACstyle's Avatar
lupe
Lupe, our local customer keeps pushing back his appointment. If you could please get some photos/ put together a brief DIY that would be GREATLY appreaciated!
www.AACstyle.com
Old 11-08-2012, 12:19 PM   #27
gbmike
gbmike's Avatar
lupe
Awesome, now that's all we're asking for, thanks so much, eagerly awaiting more pics (if that's your intention)!!
Old 11-09-2012, 07:05 AM   #28
gbmike
gbmike's Avatar
lupe
oh and one more question, I realized we keep talking driver side, what about passenger, is there an equivalent?? Or what do we do for that side?
Thanks
