Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic > Local Marketplace
Old 10-24-2012, 10:53 AM   #1
Green2SS/RS
Drives: 2011 SGM 2SS/RS
Syclone / Typhoon engine parts
I have Syclone / Typhoon engine parts for sale. PM me with any questions you may have and I will get back to you as soon as I can. $8500.00 takes it all, this is almost a complete engine does not need much more to run.
Fully machined Typhoon block with splayed 4 bolt mains and .030 over $600
Used stock Typhoon cylinder heads unassembled $300
New Brodix aluminum cylinder heads (valve seats need to be cut) $1300
Used ported lower intake manifold $250
Used half ported upper intake manifold $250
New custom cam and valve springs $360
New valve retainers $40
Used stock pushrods $40
Used stock roller lifter guides $40
New hydraulic roller lifters $150
Used Kenne Bell headers and cross over pipe with external waste gate flange all ceramic coated and not used after coating $800
New stock down pipe $100
New stock cross over pipe $200
Balanced rotating assembly with stock crank shaft, new Ross dished pistons, stock rods, new rings, new bearings, new flex plate, and new fluidamper street balancer $2000
New ITS turbo GT66 stainless ball bearings .81 ceramic coated exhaust housing $1800
New braided turbo drain line $80
New (6) 75# injectors $350
New billet fuel pressure regulator $110
Used stock throttle body with foil $80
Plus other random brackets and hoses that I’m not sure what they are for but came off this engine.
Here is a link to the pics.
http://s742.beta.photobucket.com/use...yphoon%20parts
Green2SS/RS is offline   Reply With Quote
