Jason 98 TA
Old 10-24-2012, 03:37 PM   #1
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
battery tender/charger
Need to purchase a battery tender for winter storage. What are your recomendations. Thanks in advance I need to order this thing ASAP.
Laus Deo
charlietuna is offline   Reply With Quote
Old 10-24-2012, 03:42 PM   #2
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Highly recommend Battery Tender Junior. Buy off Amazon.com free shipping. They offer a 3 pack - but don't buy it. The 3 Pack, although cheaper on an each basis, does not offer the free shipping and ends up costing more than buying them "each" basis.
But I use the BT Juniors.. Excellent results.
htron50 is offline   Reply With Quote
Old 10-24-2012, 03:43 PM   #3
01pewterz28
Camaro Junkie
01pewterz28's Avatar
I picked up a some battery tenders from Harbor Freight if I recall $10 EA so far after 8 years of use on the 2000 Camaro, 2001 Z/28, and the 69 Z/28 thye are still working great.
**FIFTY HBM 2SS VERT**
Old 10-24-2012, 03:47 PM   #4
charlietuna
Drives: 2013 ZL1
ok are you hooking it up under the hood or at the battery posts in the trunk?
Laus Deo
Old 10-24-2012, 03:50 PM   #5
Russell James
Russell James's Avatar
Drives: Camaros
Either will work the same.
I've used a Battery Tender Plus for many years, still works great. It has even bounced off the concrete floor many times, they must be pretty tough.
Old 10-24-2012, 04:00 PM   #6
VR1LE
lighten up Francis
VR1LE's Avatar
Drives: 2013 Camaro 1LE
same here been using the Battery tender for years with good results.
1SS 1LE track rat ordered 10/19
Arrived at dealer 12/26/12 after hours delivery
VR1LE is offline   Reply With Quote
Old 10-24-2012, 04:20 PM   #7
Hercules
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9
I know this is kind of off topic but do you recommend pulling the battery completely or just using the battery tender?
Hercules is offline   Reply With Quote
Old 10-24-2012, 04:32 PM   #8
HDRDTD
If it's just for winter storage, there's no need to disconnect the battery. A tender will be just fine.
Old 10-24-2012, 04:55 PM   #9
Hercules
Thanks again, I wasn't sure which would be best. Now to get a tender tomorrow.
Old 10-24-2012, 05:34 PM   #10
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Battery Tender Junior is great. Nice and small, basically just a wall wart and alligator clips to the battery. I connect mine right to the battery, run the wires to the ground and up under the front fender to a wall outlet near the car, and forget about it. You can fully close the hood this way, and don't need to disconnect anything. Just remember it's hooked up before you go to start or move the car in the spring!
joeybsyc is offline   Reply With Quote
Old 10-24-2012, 05:43 PM   #11
Supermaro585HP
Drives: 2011 Camaro SS RS
I have 2 amps and a sub box in my trunk. Is it ok to hook one up under the hood?? I stored mine last winter and never used one and didn't have any problems. Are they really nessary
Supermaro585HP is offline   Reply With Quote
Old 10-24-2012, 06:43 PM   #12
Snakedriver
Snakedriver's Avatar
Drives: ZL1
I have the battery tender ring terminal harness permanently attached to the POS and NEG so I can just plug in my battery tender plus whenever the car is going to sit for a while.
Snakedriver is offline   Reply With Quote
Old 10-24-2012, 06:57 PM   #13
htron50
htron50's Avatar
I pop the hood when I get home, let the engine cool down, and hook up the Battery Tender under the hood!
Old 10-24-2012, 07:27 PM   #14
charlietuna
Drives: 2013 ZL1
THANKS TO ALL I JUST ORDERED THE JR....... I keep trying to delay putting my ZL1 to bed for the winter.
Laus Deo
