Emblempros
Old 10-24-2012, 09:07 PM   #15
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
So we dont know.
tramtwo is offline   Reply With Quote
Old 10-24-2012, 09:45 PM   #16
KarFan
KarFan's Avatar
Drives: CARS
GM didn't re-certify the HP/Tq ratings of the LS3 with 1LE options. They used the same SAE rated figures the LS3 has had in the Camaro M6 since 2010 MY.
The 1LE optioned LS3 with electric steering and dual mode exhaust should have more power than the standard SS variant.
But owners will have to prove it with dyno and performance testing on their own.
KarFan is offline   Reply With Quote
Old 10-24-2012, 10:52 PM   #17
toehead93
Drives: 2014 2SS/1LE
Originally Posted by natmad View Post
Seems to be some confusion about the 3.91 gears. Along with the change in the rear end to 3.91 gears, the 1LE also gets different transmission ratios making overall performance in each gear (1-6) similar. I think the main differences will be seen in 2nd, 3rd and 4th for increased road course performance. Someone with internet skills can probably link to the gear ratios and speed at redline info for each gear from another thread.
Putting 3.91 gears in a standard SS would make much more of a torque multiplying type effect at the wheels that some are talking about.
Good point that i forgot about. The 1LE is making more power to the ground with the lighter wheels and tires also. This reduction in unsprung weight will help accelerate and brake better.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-24-2012, 10:55 PM   #18
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
I heard in another thread that the dual mode exhaust doesn't add any horsepower to the rear wheels. It was said that no aftermarket cat-back systems add power, they're strictly for sound if you don't add headers. Not sure how true that is.
Old 10-24-2012, 11:12 PM   #19
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Well all I know is that for me coming from a ss vert with gm's 21's and an extra 200+ pounds I am sure to be impressed!! Especially after I put on the headers and cai on and let Ted have a go at it.
Am willing to offer the car for science... anyone local want to do some before and after dyno testing?
Old 10-25-2012, 12:22 AM   #20
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Unless the dual mode exhaust diverts before the cats, it won't make much if any difference. If anything, it will add more weight.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-25-2012, 12:46 AM   #21
Kent2010
Drives: Camaro SS
Originally Posted by toehead93 View Post
Fake torque = REar wheel torque that you see on a chasis dyno. I think a lot people consider theis real torque since this is the actual power getting to the ground. An engine can make all the power in the world but if you cant get it to the wheels efficiently it is worthless. The manufacturer engine ratings use flywheel ratings from an engine dyno.
So if I put some 4.56 gears in my stock SS, and go put it on a chassis dyno, that dyno will now show my car as making more torque than all other stock SS Camaros? And since the Horsepower number that the dyno gives me is actually mathematically derived from the torque curve, I now have more HP than stock too?
Kent2010 is offline   Reply With Quote
Old 10-25-2012, 04:56 AM   #22
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Originally Posted by SUKXOST View Post
lets not forget about the electric steering and the NPP exhaust possibily providing an ACTUAL additional bump.
Not following why the steering helps?
CrystalRedTintcoat is offline   Reply With Quote
Old 10-25-2012, 05:49 AM   #23
newb
newb's Avatar
Drives: 2013 1LE
Usually the power steering is run by a hydraulic pump belt driven by the engine. By having to drive the ps pump it took Hp away from the total Hp available to drive the car. By going electric assisted ps, that is 1 less thing for parasitic loss. Essentially freeing up a few Hp to the flywheel, transmission and down the line to the wheels.
Sent from a rainbow while riding a unicorn
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 10-25-2012, 08:37 AM   #24
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
NPP is significantly lighter and reduces backpressure. It does make more power on the vette after the cats, but requires a different engine call I think. Anyhow, if u do any other mods and get a tune, the NPP will help you
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 10-25-2012, 08:38 AM   #25
Mgizzle
Mgizzle's Avatar
It doesnt use energy from the engine due to not having a mechanical pump. Hence, less load on motor, better fuel efficiency and maybe more power.
Old 10-25-2012, 09:08 AM   #26
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
What you said
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 10-25-2012, 09:40 AM   #27
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I was curious why GM hadn't put up different HP/TQ numbers for the Dual Mode Performance Exhaust like they do on the Corvette.
That exhaust has my attention as an option because I figure it is at least as good as the average cat back aftermarket exhaust just add headers and your exhaust is done and it gives you the option of being civilized when you sneak home at 3am... wouldn't want to wake up the wife...
Firefighter is offline   Reply With Quote
Old 10-25-2012, 10:16 AM   #28
SUKXOST
SUKXOST's Avatar
Very likely to keep down insurance for buyers
