Gen5DIY
Old 10-24-2012, 06:33 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Coloring a MagnaCharger.....???
I guess this is the right section. Was going to put it in the cosmetic section but need some of the physical experts to weigh in. Found another thread but it was for new buys.
If I wanted to powdercoat or paint my Maggie Orange how would I do it?
Would powdercoating make it hold too much heat?
Would it have to be taken apart? (which is a no go at this station)
Can it even be done now?
Old 10-24-2012, 06:54 PM   #2
Supercharged SS
Drives: 2010 Camaro
I think PC it right now would be a royal pain in the ass. Go get some high temp paint and see if that works.
Old 10-24-2012, 06:55 PM   #3
Supercharged SS
Drives: 2010 Camaro
On a side note.....if you go fast enough no one will give a crap what color your blower is!!!!!!!!!!!!!!!
Old 10-24-2012, 06:57 PM   #4
PQ
Booooosted.
PQ's Avatar
I can take it off fairly quickly but obviously baking it would be the problem. What all would have to be removed?
You may be right about painting it. But I'd be scared as hell to try it myself. If it didn't work what a screw up that would be.
I'm not that fast yet. lol
Didn't even hit 11s at the fest.
Old 10-24-2012, 07:14 PM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I've seen a yellow one before, I'd call up Magnuson and ask them, they should be able to give you a straight answer
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-24-2012, 07:14 PM   #6
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
It's a fairly ruff casting so i don't think you would have much to worry about. With some light coats you should be fine. I got the same idea about doing mine yellow after seeing the maggy install video floating around with the red one.
newagemuscle is offline   Reply With Quote
Old 10-24-2012, 07:14 PM   #7
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Mine is painted to match with factory IOM paint just put an ouce of high temp additive in with the paint mix no problem. Don't mind the broken Jack Shaft as that is out at Magnuson being fixed very early model maggie issue only no worries!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-24-2012, 07:15 PM   #8
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
I was going to try it but my local powder coater said I would have to remove the wrinkle black coating (Pain in the ass) I agree with the high heat rattle can appraoch.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 10-24-2012, 07:15 PM   #9
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Size:  23.5 KBOh Boonnnnieeeee
Old 10-24-2012, 07:41 PM   #10
Synner
Drives: 2011 2SS/RS M6
Pretty sure they coat before machining at the factory. For something like that I would recommend paint versus potentially causing even the smallest amount of warping next to rotors turning at over 15k rpm. Something that size/weight needs to stay in the oven for a while, probably 45 minutes to get it to 400 all the way through for the necessary cure time.
Old 10-24-2012, 07:59 PM   #11
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
THAT IS EXACTLY WHAT I WANT MINE TO LOOK LIKE !!!! I have a red Maggie and it would look a million times better if it was orange. That looks INCREDIBLE
More details please Gotthat02fire
Big C CamaroSS is offline   Reply With Quote
Old 10-24-2012, 08:01 PM   #12
Big C CamaroSS
Oh and thank you PQ for starting this thread.....I've been thinking about how to go about painting my red housing.
Old 10-24-2012, 08:13 PM   #13
rdblan2
Drives: 2SS RS
That's awesome. Going to guess that's not a rattle can job. Brush? Pro sprayed? DIY?
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 10-24-2012, 08:27 PM   #14
jordan 572
jordan 572's Avatar
Drives: none
Just a thought, maybe try plasti dip although I am pretty sure that would bake off.
jordan 572 is offline   Reply With Quote
