BeckyD@RodgersChevrolet
Old 10-24-2012, 09:32 PM   #15
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Probably, plastic and high heat don't mix well, although some people have painted things with plastidip under the hood
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-24-2012, 09:33 PM   #16
jordan 572
jordan 572's Avatar
Drives: none
Yea, pretty sure not that hot though, could try a little spot.
jordan 572 is offline   Reply With Quote
Old 10-24-2012, 09:36 PM   #17
2SS45th
2SS45th's Avatar
Very true, although I don't know if I'd risk melting plastic on top of it. You could get a temp reading, then replicate that heat on a piece of scrap metal (complicated).
Old 10-24-2012, 11:04 PM   #18
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
How about some high temp caliper paint
lionssfan is offline   Reply With Quote
Old 10-25-2012, 11:02 AM   #19
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Gotthat02fire View Post
Mine is painted to match with factory IOM paint just put an ouce of high temp additive in with the paint mix no problem. Don't mind the broken Jack Shaft as that is out at Magnuson being fixed very early model maggie issue only no worries!
I have some factory orange that my stripes on my hood were done with. Plenty of it in fact. So where do I get the high temp additive?
Originally Posted by fourmz View Post
I was going to try it but my local powder coater said I would have to remove the wrinkle black coating (Pain in the ass) I agree with the high heat rattle can appraoch.
Rattle can will get me absolutely throttled by a nameless person on here.
Attachment 436416Oh Boonnnnieeeee
She'll be glad I have my mind on something other than stress. hahahaha
Originally Posted by Synner View Post
Pretty sure they coat before machining at the factory. For something like that I would recommend paint versus potentially causing even the smallest amount of warping next to rotors turning at over 15k rpm. Something that size/weight needs to stay in the oven for a while, probably 45 minutes to get it to 400 all the way through for the necessary cure time.
Agreed. Powder coating is out.
Originally Posted by Big C CamaroSS View Post
Oh and thank you PQ for starting this thread.....I've been thinking about how to go about painting my red housing.
I might actually try this if I can find out the best way to do it.
Originally Posted by rdblan2 View Post
That's awesome. Going to guess that's not a rattle can job. Brush? Pro sprayed? DIY?
I want to know too.
Originally Posted by jordan 572 View Post
Just a thought, maybe try plasti dip although I am pretty sure that would bake off.
Negetive Ghost Rider the Maggie is full. haha
If I can't match the OEM that my grill and stripes are done with I will skip it.
Old 10-25-2012, 11:51 AM   #20
Jessika
Drives: Anything Blown
Painting is ok. The problem is baking the components when they are disassembled. That is when it is possible to warp stuff... We do offer color options for magnusons, but the warranty is voided. (I know you dont have a warranty anyway). Most likely, it will be ok, but if you warp the housing then it would be ugly...
If you can find a body shop that will paint it without disassembling it, go for it. It might not be the most perfect job, but it would still be pretty I bet.
Jessika is offline   Reply With Quote
Old 10-25-2012, 11:55 AM   #21
PQ
Booooosted.
PQ's Avatar
Yup. I'd like to know more about the heat resistant additive. I already have the IOM paint.
Old 10-25-2012, 12:31 PM   #22
Rat
Rat's Avatar
Drives: ZL1/TBSS/COPO
We had one of the Trailblazer SS ladies, make her's PINK!
She pimp'd out her trim on her truck in pink too!
Here was here write up. Holding up well too.
http://www.tbssowners.com/forums/showthread.php?t=74722
.....2012/14 COPO #33....427, 1.30 60' ....9.79@138......
Rat is offline   Reply With Quote
Old 10-25-2012, 01:58 PM   #23
SC2150
We paint them with a high heat mix to match the factory color. Ask Gene from GM Partshouse for pics.
Old 10-25-2012, 05:08 PM   #24
PQ
Booooosted.
PQ's Avatar
Prep work is 90% of the job but I'm not sure I want to try and sand the rough texture down.
So do I get the heat additive from him?
Old 10-26-2012, 03:39 PM   #25
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Any local auto paint supply store would have what you need if not get in touch and I will send you some no prob!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-26-2012, 03:43 PM   #26
Gotthat02fire
Yes mine was booth sprayed off the car with the blower torn down and about three hours of prep! The coating is not thick just good quality so knock down the ruff stuff prep all good and shoot very very very light coats should turn out well!
I'm actually pulling mine back off and apart to fix where the Jack Shaft spon losse it won't be as bad to prep but I'm sure I can DIY it for everyone!
Old 10-26-2012, 04:15 PM   #27
PQ
Booooosted.
PQ's Avatar
So I can just add it to my factory IOM and paint it then?
I guess I better go get me a cheap spray gun.
Also, I like the textured look. It will still have that right?
Old 10-26-2012, 05:26 PM   #28
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
I'd really appreciate a DIY on how to paint my red Maggie orange. I have the next 4-5 months to prep & paint.
Big C CamaroSS is offline   Reply With Quote
