JDP Motorsports
Old 10-26-2012, 01:33 AM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Break pad break in
Where in the owners manual does it say to do hard stops to do a break in of the break pads? It says not to make hard stops???
Skylane765 is offline   Reply With Quote
Old 10-26-2012, 02:13 AM   #2
Vroom
Drives: 2013 Camaro ZL1
Section 9-7. Under Brake Burnishing. Says to do it after the break in but before racing.
  • 2013 Victory Red ZL1 - 143K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 10-26-2012, 09:37 AM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
For the first 1500 miles, the manual states to go easy on the car. No hard stops, no hard acceleration, and try to keep the revs under 4000 and the speed below 80. This will "break-in" all components of the car, including the surface of the brake pads (they required a couple hundred miles of wear to become the most effective).
But further in, there's a brake-burnishing procedure, as Vroom mentioned, which is different. This requires hard ("80%") stops with frequent cooling periods between each. The procedure is to heat-treat the pads and epoxies, etc within the compound. It's not necessary unless you're racing/HPDE with the car.
Old 10-26-2012, 12:15 PM   #4
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Break-in Period
No hard braking first 200 miles, then you're suppose to take it easy for the first 1,500 miles. Best advise I got was to go thru all the modes during the break-in period. Started in Touring mode for a hundred miles or so then changed to Sport mode for a hundred or so, and now I'm in the PTM modes. Today I'll start out and use PTM 3. Probably tomorrow as well, I'll try to rack up a couple hundred miles in three then try out PTM4. Still following the break-in procedures, 4,000 to maybe 4,500rpm's and topping out at around 80 to 85. Not easy to keep it that low and slow. But that's what's recommended, so I'm going to follow the advise of the experts.
Normagene is offline   Reply With Quote
Old 10-26-2012, 01:37 PM   #5
Skylane765
Skylane765's Avatar
Thanks guys, looking at the video, you would think they want you to burn in the breaks at break time. Now I understand to just go easy at first.
