sjm autoprod
Old 10-26-2012, 09:30 AM   #1
black1105
Drives: 2013 Black ZL1
AAC's ZL1 Plasma LED Fog and DRL Bulbs
I just purchased the AAC's Plasma LED Fog & DRL bulbs for my ZL1 & I found out that some people had issue with their bulbs . It may have been regular LED bulb instead of Plasma type.
Anyway, I just want to confirm before the installation. Is there instruction how to install these bulbs? It's not same as regular Camaro due to Front Lip Spoiler.
black1105 is offline   Reply With Quote
Old 10-26-2012, 11:35 AM   #2
DangerZL1
Drives: Future ZL1 Owner
I've heard the install is the same, by removing the Torx screws on the outer edge of the wheel well liner and pulling it back you should have access. This also requires removing the tire.
DangerZL1 is online now   Reply With Quote
Old 10-26-2012, 01:22 PM   #3
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
You do not have to remove the tire. Just turn the tire to the farthest it will go, depending on how big you are this should give you enough room to get your hands inside the liner.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 10-26-2012, 03:58 PM   #4
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
also note that the P13W leds will not fit securly as the fitting changed, so you will need to do a little modifcation to ensure they stay in correctly
I'm waiting for the correct fitting LEDs that will snap in securely before ordering
Modern07 is offline   Reply With Quote
Old 10-26-2012, 04:02 PM   #5
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
I have P13W's and mine fit perfectly. I have an early build though and I believe there was a change in fittings on later builds.
Deke736 is offline   Reply With Quote
Old 10-26-2012, 04:03 PM   #6
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
Mine fit in perfect, no modification or anything just plug and play. Fits the exact same way as the stock ones, perfect fit and rid of that piss yellow look..
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels
604 RWHP 602 LBS/TQ
ZL1 Spoked is offline   Reply With Quote
Old 10-26-2012, 05:38 PM   #7
Modern07
Modern07's Avatar
Did they Snap into place or are they loose?
Late 2012's and 2013 have a different fitting than P13W - similar, but you have to break a tab before it will fit - maybe AAC did this for you first so you didn't notice, but regardless it wouldn't snap until place still
Old 10-26-2012, 05:55 PM   #8
jameslk55
jameslk55's Avatar
Drives: 2012 2LT/RS, 2005 SLK55 AMG
No problems with my plasmas (knock on wood). The DRL bulb tab should already have been shaved by AAC. You can see where the tabs used to be. I would just turn the wheels all the way and loosen the wheel well bolts. I used 4 zip ties to secure each DRL bulb but I did a ZL1 front end conversion-everything was off the car for easy access.
Not sure about the 2013s...
jameslk55 is offline   Reply With Quote
Old 10-26-2012, 07:45 PM   #9
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
They just snapped in perfectly, they had the same exact tabs as the stock ones. Nothing was done to them they were exact fits.
604 RWHP 602 LBS/TQ
Old 10-26-2012, 08:10 PM   #10
Modern07
Modern07's Avatar
Hmm...Well now I'm confused...I read all the threads about them not fitting the 2013s properly....only one way to find out though!
Old 10-26-2012, 08:31 PM   #11
OVERPAR73
2013 CRT ZL1 convertible
OVERPAR73's Avatar
Drives: 2013 ZL1 vert
I installed mine with no problems at all on my 2013 ZL1 convertible. All I did was remove the screws on the bottom outside lower valance, pull it down a little for my arm to fit up and remove the old ones and swapped them out with no problem. They look really nice! I will do the same procedure on the front sidemarker lights when I finally receive them from AAC (LED, ghosted, painted). I will take before and after pics.
OVERPAR73 is offline   Reply With Quote
Old 09-09-2013, 09:49 AM   #12
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 16 BMW M5 & 15 Z/28
Anyone have any pictures?
URBAN LEGEND is offline   Reply With Quote
Old 09-09-2013, 10:25 AM   #13
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Mine didn't snap in either I had to southern engineer mine also.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 09-09-2013, 11:16 AM   #14
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
I had to modify the tab on mine too....have had no issues with them coming out, in fact I hit a bobcat and it broke the bulb loose from the housing (still worked, little quick steel, good as new), but never came out of the connector!!!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
