Rick@Livernois
Old 10-26-2012, 09:00 AM   #1
MidnightNitemare
W.I.P
MidnightNitemare's Avatar
Drives: imperial metallic blue camaro zl1
Send a message via Skype™ to MidnightNitemare
drag tips?
First time headed to the tracks and i just wanted to have some insider tips on the dos and donts like what traction setting one click two click or hold down 7 seconds what light to take off in what rpm to stall in a stock converter paddleshifter vs fully auto?
MidnightNitemare is offline   Reply With Quote
Old 10-26-2012, 11:11 AM   #2
tjk_art
Drives: 2010
is that your car in your avatar?
tjk_art is offline   Reply With Quote
Old 10-26-2012, 12:08 PM   #3
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
deflate tires to 25 psi.Turn the nannies off. Leave at 1000-1200 rpms.Do NOT use the paddle shifter. Leave shifter in "m" position....This should get you started...adjust
as needed.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 10-26-2012, 12:10 PM   #4
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Hopefully you're headed to the Camaro meet in my sig.
You'll get all kinds of good personal instruction there.
Old 10-26-2012, 12:11 PM   #5
sycraft
COTW 5/06/2013
sycraft's Avatar
http://www.rangeracceleration.com/
This !
Old 10-26-2012, 12:56 PM   #6
MidnightNitemare
W.I.P
Thanks to all the advice guys really appreciate it wish me luck
Old 10-27-2012, 06:41 PM   #7
flyer08
Drives: 2010 2SS/RS
as needed.
Why would he not use paddle?
flyer08 is offline   Reply With Quote
Old 10-27-2012, 07:10 PM   #8
Quick
Quick's Avatar
Paddle shifting is too inconsistent. You'll either shift early or hit the rev limiter.I have tried it several times and not once did I get a good run using them.Most the time when you leave the light your weight is pulled backwards enough to shift the car into second before it has a chance to roll out.If you try to leave without having your hand positioned on the wheel where you can shift it will spool up too fast and hit the rev limiter before you can reach it. He(op) asked paddle shifter or full auto...I recommend letting the computer shift the car for you.
