Emblempros
Old 10-27-2012, 08:26 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Tampa Tuning Saturday dyno tune price specials
From now till December 15th, Tampa Tuning is offering a Saturday dyno tuning out the door price special with the dyno time included.
To dyno tune a Camaro from stock to bolt ons the cost is $350.00
To dyno tune a Camaro with aftermarket internals (cam) $420.00
To dyno tune a Camaro with Forced Induction $500.00
Tampa Tuning will performance:
  • Read and reprogram your PCMs settings and perform real time scan diagnostics for the best results
  • Increase power enrichment rate mode
  • Examine and change timing tables for additional horsepower & torque gain
  • Optimize your vehicle’s Air and Fuel Ratio monitored with a wideband
  • Reduction of Intake Air Temperature table (heat soak prevention)
  • Desired rev limiter adjustments
  • Park, neutral, and in- gear idle adjustments with and without A/C active as needed
  • Adjust power enrichment delay
  • Engine torque management system reduced
  • Transmission torque management system reduced
  • Transmission shift points enhanced
  • Transmission shift times reduced
  • Transmission shift firmness enhanced
  • Skip shift deleted (CAGs 1st to 4th shift)
  • Fuel injector rescaling for aftermarket injectors
  • Cooling fan activation temperature recalculated
  • Perform speedometer recalibration for rear gear ratio and tire size change
  • Turn off check engine light and remove trouble codes
  • Neutralize rear oxygen sensors that cause CEL
  • Idle calibration
  • Start up airflow calibrated
  • Long Term Fuel Trims dialed in
  • Open and closed loop calibration for optimized results
  • Disable Displacement on Demand ( AFM)
  • ...and other performance calibrations to achieve maximum safe results
www.TampaTuning.com
You can reach me at Tuning@TampaTuning.com
or call for appointment 813-727-8720
Burn your tires not your wallet
Phil
Tampa Tuning is offline   Reply With Quote
Old 11-07-2012, 05:35 AM   #2
Tampa Tuning
camaro corvette performance tuner in Tampa Orlando
Mid week bump to save a buck
www.TampaTuning.com
  • Idle calibration
www.TampaTuning.com
Phil
Old 11-23-2012, 10:39 PM   #3
Tampa Tuning
Camaro Corvette C7 GTO performance Firebird Truck tuner in Tampa Orlando
saturday bump
Tuning@Tampatuning.Com
  • Idle calibration
www.TampaTuning.com
Phil
Old 12-27-2012, 06:23 PM   #4
Tampa Tuning
Camaro Corvette GTO CTS G8 Firebird Truck performance tuner in Tampa Orlando
We're back to everyday Tampa Tuning low pricing for performance calibration:
Everyday Tampa Tuning pricing:
Custom Street Tune for Bolt-On and under vehicles. $280.00
Custom Dyno Tune for Bolt-On only $380.00
Custom Dyno Tune for internally modified with Cam and or Heads $450
Custom Dyno Tune for Forced Induction $550.00
You can contact me by Email at:
or call me at 813-727-8720
Or through our website at:
www.TampaTuning.com
Phil
  • Idle calibration
www.TampaTuning.com
Phil
