JUICEDMOTORSPORTS
Old 10-27-2012, 08:16 AM   #1
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
1LE specific tune?
Any of you tuners haves something in the works? Will a 1le specific tune even be necessary... I mean because of the MN6 transmission and final drive ratio of 3.91 being different than the SS?
tramtwo is offline   Reply With Quote
Old 10-27-2012, 11:48 AM   #2
Synner
Drives: not stock
Theres nothing unique about an LS3 with 3.91 gears.
Old 10-27-2012, 11:58 AM   #3
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
So the different gearing ratios because of the MN6 transmission is irrelevant to a tune? That cant be right, can it?
Old 10-27-2012, 12:03 PM   #4
Synner
Drives: not stock
The engine needs an optimum tune at whatever rpm, theres a couple things that need to be changed for rear gears but its no different on the 1le than on any other camaro with a change.
Tranny gearing will change the rpm the engine is at for a certain speed, the optimal tune for an engine at a given rpm isn't altered. People just need to be smarter about cam changes that kill the midrange for their dyno queens.
Old 10-27-2012, 12:04 PM   #5
VR1LE
lighten up Francis
VR1LE's Avatar
Drives: 2013 Camaro 1LE
Since their is less load on the low rpm due to the torque multiplication factors involved you could probably get away with a little more timing on the bottom end, this is a question for the tuners out there as I am no tuner just my thoughts from being around this stuff for so long.
1SS 1LE track rat ordered 10/19
Arrived at dealer 12/26/12 after hours delivery
VR1LE is offline   Reply With Quote
Old 10-27-2012, 12:21 PM   #6
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Thanks for your reply.
Old 10-27-2012, 01:00 PM   #7
Synner
Drives: not stock
Have you done the math on the gearing? The tranny and rear will mostly cancel out but I'm not sure the exact numbers. I think it's a tad higher than standard, can't remember the thread where they measured it out. It's the close ratio that is the primary benefit so no short shifting 1st/2nd.
Old 10-27-2012, 03:44 PM   #8
VR1LE
lighten up Francis
VR1LE's Avatar
ok got it that makes sense thanks
Old 01-12-2013, 04:12 PM   #9
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Looking to install my headers....
Old 01-15-2013, 08:17 AM   #10
Kelly@PCMofNC
Drives: 2010 RS/SS
The fact that it is a 1LE won't make the job any different for the tuner, they'd still do it the same way. Load a base program, adjust fuel trims, timing, and other small things that help with driveability, and then finish up on the dyno to fine tune the air fuel ratio and figure out what timing works best for it. As far as having different final drive ratios, that information is already part of the stock operating system, so when you read that file out it's not something you have to factor in, if that makes sense.
Good luck with the headers, they are a nice addition to any LS3!!
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
