JDP Motorsports
Old 10-27-2012, 07:08 PM   #1
Mil
Drives: 2013 Victory Red w/ automatic #671
Stumbling and Bogging from dead stop in 1st Can't Launch or Burn it up??
ZL1 Start from dead stop, Stumbles are Boggs .. Can't do a burn out.
Traction control turned off, Start from first gear punching the exhilarator car stumbles nearly bogging out .. cant do a burn out.. then picks up and go..
Noticed i have this issue after i did the ecm fuses 5, and 20 pull.. before that my ZL1 could put down the pwr to the rear and smoke em up .. . now i'm regretting i did the fuse pull out of curiosity. I never ran anything less than 93 octane fuel .. i were one of the few people that probably did not need to do the fuse pull but did it anyway out of curiosity.. anyone have any ideas what''s going on.. could it be something else coincidentally that developed after i did the fuse pull could it be have a vacuum leak some where?????
Mil is offline   Reply With Quote
Old 10-27-2012, 07:12 PM   #2
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
No, the computer is programmed to pull 2-3 degrees of timing with a WOT start. Why, I don't know.
jimmy5 is offline   Reply With Quote
Old 10-27-2012, 07:25 PM   #3
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
How many miles are on your car? I speculate that the ECM fuse pull probably also wipes fuel trims as well as the knock retard table. It is possible that you may need to drive the car normally for a bit to let the fuel trims relearn.
Blueclyde is offline   Reply With Quote
Old 10-27-2012, 07:27 PM   #4
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I can't think of any reason fuse pull would do this it actually woke my car up.
datalog is kind of what you need to see. hold down for 7 senconds turn the stabilitrack and t/c off.
the car should do a burnout.
even if the car pulled 2-3 degrees of timing it would still melt the tires down from a dead stop. it has 580hp.
if the car is boggin something is stepping in or the car is not running propperly.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-27-2012, 08:51 PM   #5
kbar4782
kbar4782's Avatar
Drives: 2012 ZL1, 00016
The very first time I really ripped on mine with about 200 miles on it it did the same thing. I drove it and put some miles on it and I haven't experienced it again. I read a thread on this same thing a long time ago and it was explained. I jus don't remember what it was
kbar4782 is offline   Reply With Quote
Old 10-27-2012, 08:52 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
exhilirator? sorry...damn
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-27-2012, 09:06 PM   #7
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
stikSS is offline   Reply With Quote
Old 10-28-2012, 02:36 AM   #8
Mil
1,564 miles; I'll try that until i reach next 500 miles.
Old 10-28-2012, 02:37 AM   #9
Mil
Originally Posted by stikSS View Post
Yeah; I were too lazy to do spell check.
Old 10-28-2012, 02:49 AM   #10
Mil
I took delivery at 19miles; at 200 miles I felt all 580horses burning a hole in my wallet smoking up the rear tires. Dang wish you could find this thread..
Old 10-28-2012, 02:51 AM   #11
Mil
Folks pls keep this thread alive... I bet someone out there knows.
Old 10-28-2012, 04:24 AM   #12
Stephen12ZL1
Drives: '17 ZL1 A10
I heard from my tuner after a fuse pull it puts the ecm into the low octane table and it takes a while for the ecm to "catch up". Drive it more and it should learn and work itself out. Double check your fuses too. Maybe disconnect the battery for a few minutes then reconnect and drive...couldn't hurt.
Old 10-28-2012, 12:46 PM   #13
Oneslowz28
Drives: 2012 Camaro ZL1 #1265
I did the fuse pull on mine and did not have any issues. The car actually feels a little pepier. Still have to problems breaking the tires loose shifting through 4th gear.
Oneslowz28 is offline   Reply With Quote
Old 10-28-2012, 01:20 PM   #14
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
which fuse do you pull? And how long?
I thought the fuse pull puts it high octane?
Skylane765 is offline   Reply With Quote
