Emblempros
Old 10-28-2012, 05:39 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
hitting rev limit
When i start out and punch the gas, it will pull to 3500rpm, then it seems as if something gets stuck, and revs to the limiter if i let it. If i pull a little off the gas pedal it shifts, then quickly shifts to the next gear.
This has been going on a while, and i have tried two tunes, but they do not correct it. I am mostly sure it will be hardware. I have a throttle body and halltech cai. I do not have to Punch it, i just need to take of spirited for it to act up.
Has anyone else had this issue or seen it? Can a throttle body cause this issue by sticking open?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
