Emblempros
Old 10-29-2012, 07:55 AM   #1
basecar
Drives: 2013 Crystal Red RS
Bird droppings
Parked by a tree (wrong thing to do), got bird droppings on the hood. Doesn't seem to come out with wax. Looking to see what others have done to get the droppings out.
basecar is offline   Reply With Quote
Old 10-29-2012, 09:07 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Try clay first, but ultimately you'll probably have to try polishing....good luck
Lil' Nasty is offline   Reply With Quote
Old 10-29-2012, 11:46 AM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Clay it, and see if it has etched. If it has, pick up some meguiars ultimate compound and polish (they are over the counter and only like 8 bucks at walmart). Apply on the etched spots in circles with microfiber applicator. Use some passion and pressure when applying. If the compound took out the etching, follow with the polish in the same manner.
If you have a DA machine, process is different. Do you have a DA machine??
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-29-2012, 12:55 PM   #4
basecar
What's a DA machine?
Old 10-29-2012, 02:44 PM   #5
ihaveacamaro
I like teeth.
Drives: #198
dual action orbital machine. It's ok if you don't have one, try the method I said above and see if it works out
Old 10-29-2012, 02:45 PM   #6
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
Those damn birds! I hate 'em! I've got the same problem, just haven't fixed it yet.
MYDLIFECRISIS is offline   Reply With Quote
Old 10-29-2012, 04:33 PM   #7
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
This stuff works well too:
http://www.poorboysworld.com/bird-sht-remover.htm
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 10-31-2012, 06:45 AM   #8
basecar
Clay bar did not work, now will try Meg x something.
Old 10-31-2012, 11:33 AM   #9
ihaveacamaro
I like teeth.
Drives: #198
Did you go over it with the clay a few times?
