sjm autoprod
Old 10-29-2012, 11:24 AM   #1
cntryman77
cntryman77's Avatar
Drives: 2010 Camaro LS
Rx breather cap "breathing" oil
ok, i have something strange happening & I'm trying to figure out what is going on...I have a Vararam & the Rx catch can & Rx breather cap...I had the Vararam first, so when I installed the catch can & breather cap, I took off the varavram breather & capped the line...everything has been on for over a year with no issues (yes the hoses are on right)...last night I could smell burning oil while out for a drive...when I popped the hood, the breather cap had oil dripping from the filter part...what could be causing this? I put the regular oil cap & vararam beather back on for now...I'll have to check the oil once the engine is cooled to see how much I've actually lost...should I be concerned & remove the catch can for now as well? I remember there was another thread saying the valve could get stuck, or the PVC orifice could get clogged
cntryman77 is offline   Reply With Quote
Old 10-29-2012, 06:25 PM   #2
rydahog
rydahog's Avatar
Drives: camaro ss
contact RX they will assist you.
rydahog is offline   Reply With Quote
Old 10-29-2012, 11:29 PM   #3
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
I had a similar issue . . . I will have a hard time explaining but I talked to Tracy and he told me what to fix and it seems to have worked so try giving him a call. Best of luck let us know how it goes.
ChadG is offline   Reply With Quote
Old 10-30-2012, 11:23 AM   #4
SC2150
Easy fix....the orfice in the barb on the passenger side valve cover becomes clogged over time. It is easy to remove with a vice grips or plyers and then drill 7/64" the top single hole and both the bottom holes:
See how tiny those bottom holes are?
Old 10-30-2012, 11:30 AM   #5
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
since Tracy gave you before pics i thought i woud add some after pics
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-30-2012, 12:08 PM   #6
Soiledflame
Soiledflame's Avatar
Drives: 2016 1LT
I want to drill the orifice too but Im unsure how deep do I drill on both sides?
I had the exact same issue, except my breather exploded
I took off the breather and uncapped the drivers side as well, as I had all kinds of issues, oil leaking from driverside head gasket in addition oil inlet, and lots of fumes like you probably experienced. It was not discussed about drilling the holes until a month ago or something.
Soiledflame is offline   Reply With Quote
Old 10-30-2012, 12:33 PM   #7
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Hmm I should prob do this before I install mine huh.
kjkjr27 is offline   Reply With Quote
Old 10-30-2012, 12:39 PM   #8
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
Could you please post a pic of where this is located on the valve cover.
its a syn is offline   Reply With Quote
Old 10-30-2012, 12:58 PM   #9
KMPrenger
KMPrenger's Avatar
Was intersted in this breather, but I've read enough "oil coming out" or "burning/smoke" stories with this breather that I'm not sure I want to do this mod any longer. Maybe down the road sometime.
Old 10-30-2012, 09:21 PM   #10
cntryman77
cntryman77's Avatar
Originally Posted by SC2150 View Post
Easy fix....the orfice in the barb on the passenger side valve cover becomes clogged over time. It is easy to remove with a vice grips or plyers and then drill 7/64" the top single hole and both the bottom ones
thanks Tracy, I'll do this as soon as it stops raining
Old 10-30-2012, 10:04 PM   #11
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
+1
JHall651 is offline   Reply With Quote
Old 10-30-2012, 10:43 PM   #12
ChadG
ChadG's Avatar
See? Tracy comes through yet again!
Old 10-30-2012, 10:54 PM   #13
JHall651
JHall651's Avatar
is this barb still used when Maggie FI is installed or is that the one that gets plugged off?
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
Old 10-31-2012, 07:31 AM   #14
DON_RAFA
NY5THGEN
DON_RAFA's Avatar
Drives: 2010 Camaro 2LT/RS/A6/SIM/IO
Worked for me
DON_RAFA is offline   Reply With Quote
