ADM PERFORMANCE
Old 10-31-2012, 09:09 AM   #15
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Originally Posted by its a syn View Post
Could you please post a pic of where this is located on the valve cover.
Originally Posted by JHall651 View Post
+1
passanger side valve cover i will try to post a pick of location later tonite depending on how long i have to stay out for halloween.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-31-2012, 10:02 AM   #16
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
Originally Posted by KMPrenger View Post
Was intersted in this breather, but I've read enough "oil coming out" or "burning/smoke" stories with this breather that I'm not sure I want to do this mod any longer. Maybe down the road sometime.
The issue doesn't appear to be a problem with the breather per se, but with an OEM PCV component. The "oil-leaking" breather seems to expose the presence of a blockage elsewhere in the PCV system. I wonder how much oil collects in the trap on the OEM clean-air line when that orifice plugs up. The aesthetic improvement using the breather-cap was worth it to me because I didn't want to use the big retro-looking breather that came with the Vararam dangling off the OEM line. The breather cap is functionally equivalent with the exception of the oil-trap that exists on the OEM line (at least I think that's what the thing in the middle of the OEM line is)
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 10-31-2012, 10:18 AM   #17
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I don't have this issue but wouldn't mind pulling out the Dremel and opening things up. The breather has shown that it does relieve pressure from the engine. But if the PCV system isn't working properly it could lead the breather not to work properly. And this clogging PCV system was the resort to a club members car bottom end to blow open because the pressure had nowhere to go. AND he was stock 100%! Also recall a few months ago ( I think it was Baylor or Smoke1LT) someone before stating that their dip stick was smoking and kept popping out. After switching to the breather problem was solved. That's why a catch can and breather is a good buy for those modding. I just need picture also where this is located to handle it today while I'm off.
Can't_C_Me is offline   Reply With Quote
Old 10-31-2012, 10:26 AM   #18
SC2150
Cant....yours is already modified. ALL RX FI cars have this done.
GM has a TSB on this as well.
Old 10-31-2012, 10:31 AM   #19
Bradrulz
Drives: 2011 Camaro 1LT IOM
Great info Tracey! Can you post a picture or someone post a picture exactly where this is located on a 2011 V6? Would like to drill this out before seeing this with my breather cap. Also how far deep are we drilling?
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
Bradrulz is offline   Reply With Quote
Old 10-31-2012, 12:25 PM   #20
cntryman77
cntryman77's Avatar
Drives: 2010 Camaro LS
The breather is there to allow the engine to pull air in, not to relieve pressure...it will allow pressure to vent if it gets too high (mine was leaking oil)...I'll try to get mine drill out this weekend (damn weather sucks)
cntryman77 is offline   Reply With Quote
Old 10-31-2012, 12:38 PM   #21
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I guess being heavy handed on a stepper bit is out of the question?
Old 10-31-2012, 12:40 PM   #22
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
Someone take their phone and snap a shot for crying out loud!
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 10-31-2012, 01:06 PM   #23
hunterv6
Always bet on Black
hunterv6's Avatar
^ i would but at work which is two hrs from my house where the car is. the pic i post were from a earlier thread so they were still stored on my pc. if no one post them before i get off i will put some on here.
Old 10-31-2012, 01:14 PM   #24
pgustavson
pgustavson's Avatar
Not my set-up, but it's at the rear of the passenger-side valve cover: (RED circle)
Old 10-31-2012, 01:15 PM   #25
hunterv6
Always bet on Black
hunterv6's Avatar
Found a pic that may help if look to the left it under the black plastic vent line on the passenger side on valve cover
Sent from my iPad using Tapatalk HD
Old 10-31-2012, 01:52 PM   #26
Angrybird 12
6 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 12 CAMARO, 16 Encore, 07 Colorado
Is this just a 2010 and 11 LLT v6 problem or does the 2012 LFX V6 have the same issue?
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
Old 10-31-2012, 01:57 PM   #27
JHall651
JHall651's Avatar
Is this just a V6 problem?
Old 10-31-2012, 03:21 PM   #28
SC2150
It is all, but usually over time and the V8's dont have much issue unless forced induction or a big NA build. The picture of the LFX shows the location in the rear of the passenger side valve cover. You can easliy remove it by twisting and pulling up with a plyers or vace grip. Then you will see one hole in the top, two in the bottom.
