JUICEDMOTORSPORTS
Old 10-31-2012, 02:29 PM   #29
Angrybird 12
6 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 12 CAMARO, 16 Encore, 07 Colorado
Originally Posted by SC2150 View Post
It is all, but usually over time and the V8's dont have much issue unless forced induction or a big NA build. The picture of the LFX shows the location in the rear of the passenger side valve cover. You can easliy remove it by twisting and pulling up with a plyers or vace grip. Then you will see one hole in the top, two in the bottom.
So all V6's will eventually have a problem with this even without a catchcan and breather?
I am not one that likes modding the engine from the way it comes from the factoryin fear one of these could end up doing more harm than good. Putting the catch can on was even a struggle for me. I don't have a breather on mine because I still have the stock intake setup.
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
Old 10-31-2012, 05:57 PM   #30
SC2150
Yes....the tiny holes get restricted from gunk buildup over time.
Old 10-31-2012, 10:59 PM   #31
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
After talking to Tracy and cleaning/expanding the holes - I would recommend to ANYONE that checking this every other oil change is a good idea. You can easily clean it out with brake cleaner.
ChadG is offline   Reply With Quote
Old 11-01-2012, 07:42 AM   #32
Angrybird 12
What is the purpose of that barb? Is it a check valve type thing or is it just a thing used to connect the tube with the valve cover? I just want to knowits true purpose and if drilling out the holes won't affect something else like letting even more oil through to the catch can.
Old 11-01-2012, 07:44 AM   #33
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Is the location the same on the LLT. Can someone post a pic of it on the LLT?
FSP tuned: 377/389
Old 11-01-2012, 08:32 AM   #34
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I do believe it is the same location
Old 11-01-2012, 08:35 AM   #35
SC2150
Same location. The purpose is to restrict the flow to slow oil ingestion....but the side effect is they are to easy to clog when so tiny.
Old 11-01-2012, 09:20 AM   #36
Angrybird 12
So you will probably get more oil in the catch can when you enlarge the ports on this.
Old 11-01-2012, 09:54 AM   #37
SC2150
Depending on the amount of blow-by and how well your rings sealed you sure could.
Old 11-01-2012, 09:55 AM   #38
SC2150
Depending on the amount of blow-by and how well your rings sealed you sure could. If left alone the pressure, and the oil with it will back-flow through the cleanside into your intake air charge if the OEM clean side is left intact.
Old 11-01-2012, 11:17 AM   #39
TooCool5
Resident Gearhead
TooCool5's Avatar
I'm cleaning mine today.
Old 11-01-2012, 12:01 PM   #40
Angrybird 12
Ok I am feeling really dumb here, what is the OEM Clean side? The only thing I have changed is adding a catch can the rest of the system is OEM.
Thanks for the info.
Old 11-01-2012, 01:14 PM   #41
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
The clean side refers to the driver's side. There is a fitting on the back of the driver's side valve cover with a hose attached that runs from there to your intake.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 11-01-2012, 01:54 PM   #42
Angrybird 12
Thanks, I haven't touched that side.
