Cold Air Inductions
Old 11-08-2012, 06:35 PM   #141
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Wow this is getting good glad to see how smooth the transformation is going.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 11-09-2012, 10:29 AM   #142
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Fabbing the piping so no new pics for a while.
Tearing the old motor apart to see what failed. Ring land destroyed on two cylinders, but the tight clearances kept it from ruining the block. As we suspected, we probably had detonation.
Sent from my PG06100 using Tapatalk 2
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 11-09-2012, 12:12 PM   #143
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Originally Posted by GretchenGotGrowl View Post
Yeah, no way I can shift faster than a computer.
Why not??? I can.........................
But seriously, you are really moving fast on this thing man, congrats!!
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 11-09-2012, 04:32 PM   #144
blackTT600
Drives: 2011 2LT M6 SC
thank you!
blackTT600 is offline   Reply With Quote
Old 11-11-2012, 02:21 AM   #145
Tavo32
Tavo32's Avatar
Drives: LFX LT/RS
Wow! Simply Amazing Gretch! You just made alot more happier and this is still just progress! Great Job! Subscribed!!!
Instagram @Tavo_32
Tavo32 is offline   Reply With Quote
Old 11-11-2012, 07:45 AM   #146
speedygonzales
speedygonzales's Avatar
Drives: 99 z71, 2012 2SS
Did you actually go from fab to destroyed in 1 day?
How did you get from this:
All new cradle and differental bushings
The cradle is back in.
The turbos are getting mounted.
To this in 1 day?
Are we to assume the 2012 LFX grenaded? Is that a word? LOL What did I miss????? I'm capable of filing in the blanks but I'de rather have an explanation.
speedygonzales is offline   Reply With Quote
Old 11-11-2012, 08:01 AM   #147
sycraft
COTW 5/06/2013
sycraft's Avatar
I believe his old ride- Gretchen, was being rebuilt as it had a low cylinder or 2
Old 11-11-2012, 08:19 AM   #148
speedygonzales
You can understand my confusion. Why not just say, "working on another project"?
Old 11-11-2012, 09:04 AM   #149
blackTT600
Same project new base car. He replaced the engine in Gretchen and took ERRY thing off and put it all on the new one. The LFX has the ability to be tuned with other tuners besides Vince at Trifecta. Good luck buddy. The LLT will never be the same thanks to you.
Old 11-11-2012, 09:47 AM   #150
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
This is going to be quite the re-build !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 11-11-2012, 11:03 AM   #151
GretchenGotGrowl
Sorry for the confusion. Here's the back story.
Right before CFest we had an issue with the LLT (broken valve cover and subsequent leak down in two cylinders). Decided to run it anyway and just buy a new motor for a forged build. We suspected it was the tune so we were a bit apprehensive about not being able to at least see the logs going forward. We investigated swapping ECUs and even buying an LFX but it all looked a lot more expensive than just trading the car in. So, we pulled the LLT motor from Gretchen and put the new one we were going to build in her. That car was then traded for the 2012. Before we got to far with this build we wanted to know exactly what failed on the original LLT motor so we could address any weak spots. Here's what we found.
About 1/8th of the ringlands on two cylinders broke off. Because the tolerances are so tight on these motors, they stayed in place and the block/heads look fine. That's the bad news. The good news is that these rods are something else...they should take a lot of punishment. The bearing are also tough -- as much as I put that engine through they look brand new. The crank looks fine as well. These are very well built motors, but the Bosch ECU is not as friendly as we would like.
So the take away is we are ordering some forged pistons and lowering the compression ratio. That will take about two weeks. After that we should be ready to tune. Hopefully we'll have some numbers early December.
Again, sorry for the confusion.
Old 11-11-2012, 11:23 AM   #152
KMPrenger
KMPrenger's Avatar
Rock on.....11s here we come.
Old 11-11-2012, 02:17 PM   #153
Tavo32
Tavo32's Avatar
Drives: LFX LT/RS
Originally Posted by HP Turbine View Post
Dang 274. I think I'm going to to need to tune mine now! I got 277 with mods and no tune.
what mods do u have?
Instagram @Tavo_32
Old 11-15-2012, 06:15 PM   #154
MrGood
MrGood's Avatar
Drives: Broken palmghetto test car
Send a message via Yahoo to MrGood
I predict you will have much better results with your new tuner.
MrGood is offline   Reply With Quote
best v6, holy crap!, twin turbo lfx, v6 fuel system
