Gen5DIY
Old 12-19-2012, 08:47 AM   #169
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Originally Posted by GretchenGotGrowl View Post
Yeah, that's a weird situation. Was texting Matt the night he was tuning yours on the street. Sounds like he's got it worked out so we'll ping him if we can't figure it out. Ryan was having a similar issue with the stock tune so we expect to run into again with the higher output.
Hey, I guess it would be boring if it was all plug and play.
Yep.. Vince has a custom OS to get around it. I was able to get the driver demand torque limitations gone from 6k+, but the brake stall off line and low RPM full throttle stuff no dice. Unfortunately I sent all my files in to HPT and its something that engineering has to look at, we're missing some tq limiter tables at this point. I was hoping EFILive may have it implemented, but I am unsure of that.
I was able to send Vince via excel spreadsheets my entire fuel/spark/idle/pe tables and he used all my values turned around into his custom OS. Problem now is that it cannot be modified because of the OS by any tuning suite but Vince's...
Matt @ FSP is offline   Reply With Quote
Old 12-19-2012, 08:49 AM   #170
Matt @ FSP
Matt @ FSP's Avatar
Hope so. 10:1 CR should help us put the boost to it. Hope we have enought fuel with the ZL1 in-tank pump.
On the V8's, I've been able to see 550-600rwhp out of this pump without a BAP. I've pushed 650rwhp with the BAP or ADM module w/ ZL1 pump... However, with the lift pump, these things are a beast of their own :P
Old 12-19-2012, 12:13 PM   #171
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I'm sure Ryan and Aaron will figure something out. EFILive has been pretty responsive so far.
That's what we are hoping. Aaron has tuned quite a few diesel's and thinks the in-tank pump is the bigger limitation at this point. We shall see.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 12-19-2012, 03:17 PM   #172
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Pistons look sweet. Shortblock should be together tomorrow. Filing rings now.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 12-23-2012, 10:37 AM   #173
GretchenGotGrowl
Some updates 12-23-2012
First off, decided to name the car Oya. That's the name of an African goddess of the tempest. Seemed fitting since I hope she will be a little tempest with the turbos on her.
Second of all, the pistons and intake box are done and ready to go in the car. Then intake is completely different. We decided to remove one of the cross supports from the front and weld in a chrome/moly tube in it's place. This allowed us to bend the tube down so we could fit this in.
It accepts a flat K&N filter the size of the opening you see there. The cover is removable and can be switched so that the opening faces rearward (street use) or forward (track use). It uses Zeus clips so it will only take a minute or two to switch it around.
Next are the pistons. The new ones are forged and have very smooth surfaces to cut down on heat build up.
The ringlands are significantly improved
and everything that could be beefed up was
Old 12-23-2012, 12:49 PM   #174
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Sexy!
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 12-23-2012, 01:04 PM   #175
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
WOW!! Just WOW!!
scrming is offline   Reply With Quote
Old 12-23-2012, 01:18 PM   #176
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Nice !!!
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 12-23-2012, 04:19 PM   #177
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
2013 V6 of the year right here. Nice job D!
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 12-23-2012, 05:12 PM   #178
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Dude. Awesome!
BaylorCamaro is offline   Reply With Quote
Old 12-23-2012, 05:59 PM   #179
Rhino79
Rhino79's Avatar
I love how they moved that first ring down a good bit, pistons are beefy. I think the additional 14 grams cam from the pins though.
Old 12-23-2012, 06:00 PM   #180
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
Fantastic!!
Old 12-23-2012, 08:53 PM   #181
GretchenGotGrowl
What were the final weights compared to stock? Any issues balancing the RA?
Sent from my PG06100 using Tapatalk 2
Old 12-23-2012, 09:22 PM   #182
Rhino79
Rhino79's Avatar
I forgot the exact numbers, but the diamonds were 14g heavier each. The ra balanced well, just had to add a lil weight to each end.
best v6, holy crap!, twin turbo lfx, v6 fuel system
