Flowmaster Exhaust
Old 02-02-2013, 04:48 PM   #393
SC2150
Thats were we have been mounting them now and much quieter.
Old 02-02-2013, 08:05 PM   #394
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Originally Posted by GretchenGotGrowl View Post
Thanks man.
I've been getting questions about how we mounted the scavenge pump so you don't hear it. The trick was getting it off the body and in the center of a support member. Here's some photos Rhino took so others can do the same.
Your welcome anything I can do to help.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 02-05-2013, 06:17 PM   #395
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
16 pages later....and I'm finally caught up!
I won't waste thread space with too much oogling. Just know I'm watching and appreciate what you're doing! , but just a little less since its on a LFX
Good luck with everything. Can't wait to see more progress
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 02-05-2013, 06:21 PM   #396
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Thanks man!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-09-2013, 12:58 PM   #397
GretchenGotGrowl
Tunes are installed and I have sent some logs to Ryan. Overall, I think we made some good progress on the pull to 40 MPH, but some other issues cropped up. Great first try and I'm sure we'll get everything worked out. May be quicker for me to just take the car back to his shop and let him do it, but right now it is giving me a chance to learn the EFI tool (way different than the old version I used).
Old 02-18-2013, 01:32 AM   #398
Abstrak
Abstrak's Avatar
Drives: 2012 AGM Camaro LS / Team LFX
I'm caught up too this is insane!!! I always been one to go to the track and watch but this makes me want to follow in your footsteps, build my car up, and race at my local track. Great build cant wait to see you on the front page and COTW. I wont be at the fest but kick ass when you get there!! Folks going be in for a rude awakening
Abstrak is offline   Reply With Quote
Old 02-27-2013, 08:09 AM   #399
GretchenGotGrowl
I dropped the car off Saturday for a few more enhancements. Last night I stopped by to drop off the new boost solenoids and to go over everything with Aaron. We are putting taller spings on to help with the ground clearance. He's still waiting on those and all the plumbing for the fuel enrichment solution, but they should come in today. Then we have to tackle the tuning. This will probably take a few weeks, but I hope to get it to Memphis for another shakedown by the end of March.
Old 02-27-2013, 08:34 AM   #400
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Old 03-08-2013, 06:39 PM   #401
GretchenGotGrowl
Fuel Enrichment Solution
Okay, just got back from the shop with some photos
This is the fueling plate the had made. It sits right below the intake manifold like the isolator for the LLT does.
This shows it from the bottom up with the intake runners, the fuel plate and the intake manifold assmbled. The tubes take the fuel to each of the intake ports.
This is the back left corner showing the fuel manifold block (verticle black piece) that feeds the fuel rails.
This is a close up to show the fuel inlets. The point straight down at 90%. This is the single port set up, but you can get dual ports to run meth or N20 in addition to the fuel. Notices the port maching they did. You can't even tell where the two pieces butt each other.
This is a better shot of the distribution system. Again, the black piece (hard to see) is the fuel manifold. The bottom line is the supply line.
Now we get to the pictures of it mounted. This is it from the driver's side.
And this is the passanger side.
This is the back of the passanger side showing the fuel solenoid. This is mounted to the fueling plate, so you disconnect the piping/wiring and it comes right off with the intake manifold and fuel plate. That makes it easy if you want to change the pills in the fuel nozzles.
This is a close up of the fuel manifold. You can see they extended the bolt that holds the HPFP cover so that piece can be retained (cuts down on the noise). It all fits back there snuggly.
If you want to keep the engine cover you have to extend the oil filler cap and also the post on the driver's side. Since we were still working on wiring I didn't get a picture of it with the cover back on, but it fits and you wouldn't know it had the extra fuel system unless you looked real hard.
Now for getting it running. At first we were going to trigger the solenoid based on RPM, but the signals we could get just weren't very reliable. So, we have a dual relay that we are going to hook up to the Meth/H20 controller and go boost reference. If that doesn't work then we'll try something else.
Old 03-08-2013, 06:42 PM   #402
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
wow... simply wow!!!
scrming is offline   Reply With Quote
Old 03-08-2013, 06:46 PM   #403
GretchenGotGrowl
We have also installed the boost solenoids on each turbo and re-adjusted the WG actuators. Hopefully that will get rid of the boost spike. That's the good news. The bad news is that we can't seem get around the throttle position issue. We have been able to rule out that it isn't controlled by MPH. It appears to be related to RPM and EFI just doesn't have those tables available at this time. They are working on it though.
Old 03-08-2013, 06:51 PM   #404
KMPrenger
KMPrenger's Avatar
Easily biggest and best build on a 5th gen V6 camaro to date. When this is all said and done, the entire Camaro5 community needs to see this beast. Front page stuff here baby lol.
Good work Derek!
Old 03-08-2013, 06:55 PM   #405
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Wow will have to put that on my list.
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 03-08-2013, 06:59 PM   #406
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Good work Derek!
That's amazing!
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
best v6, holy crap!, twin turbo lfx, v6 fuel system
