Jason 98 TA
Old 03-08-2013, 07:07 PM   #407
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Thanks guys. And if this works out, he wants to build one for the LLT. I've still got my old Black Iceolater in the shed, so he'll have a pattern to go by.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 03-08-2013, 07:09 PM   #408
GretchenGotGrowl
BTW, if anyone has an old stock torque converter laying around, shoot me a PM. We are trying to get a multi-disk TC developed for the 6L50E and need one for the R&D. I could send them my FSI, but then my car would be down for a while and I still want to get to the track in the next couple of weeks.
Old 03-08-2013, 07:26 PM   #409
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
This build is insane! If the fueling works, this could be the answer we have been looking for... Well if we can tune the LLT. I can't wait to see what an LFX could do with more fuel since those can easily be tuned!!
About the torque converter, check with v6owner. I think I saw him selling one a little while ago, he might still have it
Old 03-08-2013, 07:49 PM   #410
GretchenGotGrowl
Thanks for the lead. I just sent him a PM.
Old 03-08-2013, 07:52 PM   #411
lscamaro
lscamaro's Avatar
No problem
Old 03-08-2013, 08:19 PM   #412
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
That is gorgeous
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 03-08-2013, 08:21 PM   #413
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
This thing looks amazing and a simpler solution than I thought. If this helps there is no doubt Vince and IPF will be able to tune the LLT's better. Because instead of the LLT running out of fuel it will have to much and would be easier to dial down the flow.
Question Derek, are you using same size injectors all around or small, medium, then larger in the back. As thats where the fuel isn't pumped in fast enough?
Because if many that don't know the issue is that the back cylinders are the ones running out of fuel when we crank up the HP.
Can't_C_Me is offline   Reply With Quote
Old 03-08-2013, 08:36 PM   #414
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Mother of God. This is going to be cool(er).
Equal length fuel lines should do the trick as long as you're getting equal flow under pressure from the metering block. For the new ones, I should say. After I reread it, I saw you were refering to trying to compensate for the stock system.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 03-08-2013, 08:40 PM   #415
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Thanks guys. And if this works out, he wants to build one for the LLT. I've still got my old Black Iceolater in the shed, so he'll have a pattern to go buy.
Put me on that list for the llt.
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 03-08-2013, 09:35 PM   #416
GretchenGotGrowl
So the plan for tuning it should work for the LLT. We are basically using Power Enhancement (PE) tuning for WOT...the same thing we tried with Vince. We are going to turn this bad boy on and let it go rich and then back off the PE fueling from the DI system until we get the AFR back where we want it.
We are using the same size pills all the way around, but you could set it up with different pill sizes for each runner. Right now we have 14s in it, but we may have to go back to 10s because that's like running an 84 pill on a nitrous setup. It may be more fuel than we need and we can't back off the DI system enough. We'll see, but we just couldn't get 6 10 pills before Aaron goes overseas week after next.
It should go on the dyno next Thr. for tuning. I would be neat to try this fuel plate on a NA car just to see if there is any TQ improvement. That's effectively an 1" increase in runner length. Might end up being just as much gain as the isolater has shown for the LLT.
Old 03-08-2013, 09:39 PM   #417
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
dam 502 rwhp??
OyaGotGrowl!
nikos30 is offline   Reply With Quote
Old 03-08-2013, 09:41 PM   #418
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
This is so beautiful.
MyWorld is offline   Reply With Quote
Old 03-08-2013, 09:43 PM   #419
GretchenGotGrowl
John B.
Yeah, a single fuel rail on each side would probably work better, but they are trying to keep costs down so it's affordable. We seem to have the biggest issue with the rear cylinders, so those having the shortest fuel lines will actually help with that. The system won't be pressurized until the solenoid opens, so it will take a few milliseconds before it fully pressurizes. We'll just have to bring it on at a particular boost and back off the DI fueling in the PE tables. But I guess you suspected that from the last sentence. Just wanted to make sure everyone understood that we think the different line lengths won't be an issue.
Old 03-08-2013, 10:36 PM   #420
JohnnyBfromPeoria
Makes sense. In my haste to post, I forgot that the block was on the back of the intake, so as you said, the shorter lines to the back are actually doing this for you.
C'mon, Thursday.
John B.
best v6, holy crap!, twin turbo lfx, v6 fuel system
