Old 10-29-2012, 09:47 PM   #1
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
Groan/Grind Noise when turning slowly
So over the last week or so I've noticed a groaning/grinding noise coming from the rear when I'm driving forwards and turning slowly...it's possibly there all the time, but drowned out by the engine/exhaust at higher speeds so I don't notice it.
Anyone else had this issue, or got any ideas what it might be?
700 Miles on it so far
Couple this with the MyLink issue and it looks like a trip to the dealer is needed :(
Modern07 is offline   Reply With Quote
Old 10-29-2012, 10:23 PM   #2
Bcruse84
Bcruse84's Avatar
Drives: 2013 red ZL1
I just noticed mine doing this after a left turn. Pulled the parking brake and it changed the sound so I'm thinking its in the brakes.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Bcruse84 is offline   Reply With Quote
Old 10-30-2012, 08:04 AM   #3
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
Several people seem to be having this issue. Find a empty parking lot and do several slow figure 8's.If the noise stops its probably your rear diff making noise. If thats the problem your dealer will change out your diff fluid and possibly add some friction mod. or LS add. The tech at my dealership said that if they do this they are required to do the figure 8's after they finish.
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
Old 10-30-2012, 06:00 PM   #4
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
My car had it too. You need the rear fluid changed as its the posi unit making the groan. If you do it yourself use extra additive than just what is in the fluid
ZL1Dave is offline   Reply With Quote
Old 10-30-2012, 07:46 PM   #5
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
The cold weather will make this problem more prevalent (as we have noticed with all the recent complaints), it is most likely coming from the rear diff, I have the same problem and just popped up with colder weather. Need to swap the fluid or add some additive.
69NMYSS is offline   Reply With Quote
Old 10-30-2012, 07:59 PM   #6
big hammer
Drives: 2002 ws6
it's the heat soak.
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 11-01-2012, 08:27 AM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
We apologize for your frustrations and inconveniences that you are experiencing with your vehicle. I would highly recommend taking it to the dealership as you stated. If things don't seem to be going smoothly, please let us know and we can set up a case with GM customer service.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 11-01-2012, 08:30 AM   #8
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
There is technical service bulletin on this...change the rear diff seals, and replace fluid.....dealer should know about it:
PI0137C
Real Axle Chatter Type Noise on Low Speed Turns :
10-12 Camaros with Limited-Slip Differential (RPO G80)
Replace both rear axle shaft seals, drain/refill the differential with new fluid, GM P/N 88862624
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 11-28-2012, 11:02 AM   #9
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
I am having a similar problem with my '12 SS. What really irritates me is that I PAID my dealer to change out my diff fluid just over the Summer because I had read about what was going on with these. But I'm getting INCREDIBLE low humming noise between 1000 and 1300 or so RPMs when cruising or starting to roll. For a while i was wondering if my Borla ATAK system was vibrating incredibly or something, but I'm realizing that it's got to be this differential issue.
SOOOooo, now I'm out the money I paid to have the car serviced when in fact this is a warranty issue. What exactly should I do with this? Thoughts?
To be clear, the car makes the kind of sounds that a stick shift otherwise makes when you drive it in too low a gear for the speed, but in my car it happens when in the appropriate gear for gas mileage, during the computer assisted skip shift, or simply from a gentle roll. I've seen people refer to this as "chatter" but I don't think that's an accurate description for the sound so I want to make sure we are all talking about the same thing.
__________________________________________
Ironman John
IMJ is offline   Reply With Quote
Old 11-28-2012, 11:32 AM   #10
2012 ZL1#1658
2012 ZL1#1658's Avatar
Drives: 2012 Camaro ZL1 #1658
PI0137C
Talked to local dealer and he told me that this excludes the ZL1. Just as an FYI.
2012 ZL1#1658 is offline   Reply With Quote
Old 11-28-2012, 11:36 AM   #11
ace32x
Drives: 2013 ZL1
ive read that aswell. also ive read not to run the additive. i had a 2 way lsd in my last car and also was told not to run any additive and to stick with 75 90 gear oil, im going to swap out to motul 75 90 after my first track session in the spring. its a very good ester based oil.
2013 victory red zl1, 2012 1500 silverado, 95 nissan 240sx 383 ls1 11:1 stroker dart 225 heads ms4 cam fast 102 manifold ;D
ace32x is offline   Reply With Quote
Old 11-28-2012, 11:36 AM   #12
69NMYSS
69NMYSS's Avatar
When I took mine in for the same problem, the dealer told me there is a bulleting posted for the ZL1 to expect some chatter from the rear diff. So they did not do anything. I even mentioned it might need fluid change or additive.
Old 11-28-2012, 11:54 AM   #13
papawattz
papawattz's Avatar
Drives: 2010 Camaro 2SS/RS +2014 El Tigre
Talking
papawattz is offline   Reply With Quote
Old 11-28-2012, 01:17 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
change the fluid yourself. It will quiet down almost instantly. Use the GM LS gear oil as rx by the owners manual
'15 Z/28 #325 black a/c & stereo. 2:10.9 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
