JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 10-30-2012, 08:25 AM   #1
Ciscokid
Drives: 2013 ZL1 Vert - BRM&2014 NRB Vette
Tires - problem or driver
Just curious if anybody else is having problem keeping the tires from spinning?
Here are the conditions
Automatic (manual mode) - 2 or 3 gear
Traction set to wet in rain, ass slips worse
Traction set to dry
Temp is around 40 degrees right now.
Not really applying to much pressure on the gas
Do I need to change my tires for something all weather or is this a driver problem?
Ciscokid is offline   Reply With Quote
Old 10-30-2012, 08:58 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
It's the cold ... I have the same problems with it only being 65 out.
Old 10-30-2012, 09:06 AM   #3
Nailn it
Drives: 2013 ZL1 Ashen Gray / Manual
Tires
Nailn it is offline   Reply With Quote
Old 10-30-2012, 09:30 AM   #4
DangerZL1
Drives: Future ZL1 Owner
I was going to post similar obeservations below 60 these tires are almost dangerous. I drove it a few weeks ago in the morning when the temps first started dipping into the 50s and gave just a little more gas than required turning right from a stop and the back end got sideways. Be careful!
DangerZL1 is offline   Reply With Quote
Old 10-30-2012, 09:44 AM   #5
alex70olds
alex70olds's Avatar
Drives: 2012 ZL1 #141
37 this morning north of Houston. I know your not supposed to use the tires<40F, but I drove in this morning. Tires are slick as heck. I have not seen any cracking yet. As posted above, they get slick below 60, and progressively gets worse as it gets colder.
alex70olds is offline   Reply With Quote
Old 10-30-2012, 10:05 AM   #6
DangerZL1
I'm a little concerned about performing an evasive maneuver to avoid an accident or debris on the road in the cold weather in this car, so I don't drive it in the cold or bad weather. I'd be willing to trade handling for better all weather performance if someone made a replacement tire in this size.
Old 10-30-2012, 10:09 AM   #7
Ciscokid
I don't understand the point of buying a $65,000 car and only be able to drive it if the weather is above 60 degrees..this is crazy.
GM should provide other tire options for those of us that want to drive our car all year round.
I have the sales manager from the dealer I bought my car from looking at other options to replace the tires. I have to get these tires off the car. I drive 400-1000 miles per week and need a car I can depend on to give me control when I need it.
Old 10-30-2012, 10:16 AM   #8
affox83
System Test Engineer
affox83's Avatar
Drives: '12 ZL1 #1011
Try these. Found them on Tire Rack myself as well...
http://www.camaro5.com/forums/showth...ght=cold+tires
Personally, I have had no issues with the Goodyears down to 50 degrees. Once they warm up a bit they aren't bad, even in the cold. I know they have lost some performance, though, so I don't try any cornering heroics. I can vouch for quick lane changes in 55 degree temps at faster than UT speed limits with no problem, however. Just don't hammer it at low speeds while turning.
Hope these work for you.
affox83 is offline   Reply With Quote
Old 10-30-2012, 01:20 PM   #9
hognutz
hognutz's Avatar
Drives: 2013 ZL1
its the temps. change out the tires for a more all season. they will proabably have better grip in those temps.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-30-2012, 01:27 PM   #10
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Definetly the weather, these tires do not like cold. However, GM was very forward about the perfromance of the tires in cold weather. They stated several times these are summer performance tires and should be stored when temp drop below 40*, this is a performance vehicle designed on the ring and various other tracks. This is not a vehicle designed to plow through snow or skate across ice, at least not on the G:2 tires.
69NMYSS is offline   Reply With Quote
Old 10-30-2012, 02:54 PM   #11
Ciscokid
So what are the recommended all weather tires for the car? Any recommendations?
My dealer doesn't even know what kind of all weather tires to put on the car.
Old 10-30-2012, 03:08 PM   #12
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
Pirelli Winter 210 Sottozero
Jeff65SS is offline   Reply With Quote
Old 10-30-2012, 03:53 PM   #13
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Yep was recommended by Fbodfather way back when and was shown on the CTF vehicles they were testing in the winter...
mmarx82 is offline   Reply With Quote
Old 10-31-2012, 06:39 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Because with anything other than full-summer tires...the car could not perform like the $55,000 it costs.
I've been driving it every day in 45-50º around here, lately...in the wet at those temps, too...you just need to be careful for the first few minutes of driving. Once they warm up, it's not bad at all. Also - PTM mode 1 (in the wet and pre-warm tires) helps a lot!
Always be mindful of the driving conditions, like any other car!
