JDP Motorsports
Old 10-31-2012, 06:10 PM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
anybody using a CR Spotless De-ionized Water System
Wondering if you tried a different brand of resin? They seem to charge a lot for their resin. I see other brands for 1/3 of the price.
Also, how many washes are u getting between refills?
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 10-31-2012, 07:20 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I want it so bad. I've only heard the best things about this system. It would be wonderful to not have to worry about waterspots for once!
Unfortunately, it's out of my price range so I can't help you... but one day this is what I'm probably going to get.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
