sjm autoprod
Old 11-01-2012, 07:56 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Build sheet
Does anybody know where the build sheet is on the ZL1?
Skylane765 is offline   Reply With Quote
Old 11-01-2012, 08:51 PM   #2
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
look in the trunk under the matt
Laus Deo
charlietuna is offline   Reply With Quote
Old 11-01-2012, 09:02 PM   #3
starhutch
THE RED ROCKER
Drives: 2013 ZL1 VR
Got lucky, Oshawa build team left mine in the trunk when I picked it up, framed and looks nice on the wall of the garage.
starhutch is offline   Reply With Quote
Old 11-01-2012, 09:52 PM   #4
Skylane765
Skylane765's Avatar
I looked in the trunk, I did not see it. Is there a way to get one?
Old 11-01-2012, 10:52 PM   #5
Blues45th
Drives: 45th anniversary edition v6 3.6L
My dealer pulled up my 45th in a matter of a minute. Not original but has everything an from gm
Blues45th is offline   Reply With Quote
Old 11-01-2012, 11:11 PM   #6
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
I got lucky also. The build team signed and wrote a little note my build sheet and left it in the car for me.
Smittty is offline   Reply With Quote
Old 11-01-2012, 11:14 PM   #7
ZL1speed
Drives: 2013 ZL1 Victory Red
Mine was in the trunk, also had one signed left in the center console
ZL1speed is offline   Reply With Quote
Old 11-02-2012, 12:02 AM   #8
Skylane765
Skylane765's Avatar
Yes, there is a build sheet that is a sticker in the trunk, that says do not remove.
I would think it is the same as the paper one.
Old 11-02-2012, 09:53 AM   #9
starhutch
THE RED ROCKER
Drives: 2013 ZL1 VR
Dont know what sticker you are referring to, mine is a roughly 11 x 14 build sheet chassis mainline rider document.
Old 11-02-2012, 11:57 AM   #10
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Same here.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 11-02-2012, 11:59 AM   #11
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
console, signed
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 11-02-2012, 07:34 PM   #12
Skylane765
Skylane765's Avatar
If you look under the trunk cover there is a sticker with the build sheet on it. It has all parts that where used.
Old 11-02-2012, 08:00 PM   #13
rexdogg
Drives: 2013 IOM ZL1
dealer gave me mine.........
rexdogg is offline   Reply With Quote
Old 11-02-2012, 08:25 PM   #14
Skylane765
Skylane765's Avatar
I will talk to my dealer.
