JUICEDMOTORSPORTS
Old 11-03-2012, 12:04 PM   #1
Nadine
Drives: 2013 ZLl
Bright Headlights
I keep getting warned that bright lights are on when they are not on at night so to be respectful to other drivers at night what can be done to lessen the intensity or direction of lights?
Nadine is offline   Reply With Quote
Old 11-03-2012, 12:08 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Nothing ...
Old 11-03-2012, 12:14 PM   #3
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Flash your brights, it'll shut them up...... I get it all the time with my halogens... people don't realize that you can't have fogs and headlights on at the same time... I drive with my fogs on all the time.
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 11-03-2012, 12:39 PM   #4
BigDogZL1
Drives: ZL1
Putting strips of duct tape over your headlights would work however I wouldnt recommend doing this.
BigDogZL1 is offline   Reply With Quote
Old 11-03-2012, 12:46 PM   #5
Sevn86
Sevn86's Avatar
Nothing. Let them keep flashing u. I actually have HIDs in my fogs. No one flashes me. I guess it depends on ur area.
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 11-03-2012, 09:36 PM   #6
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
Maybe they're aimed too high.
1MtnGoat is offline   Reply With Quote
Old 11-03-2012, 09:39 PM   #7
Swacer
Drives: 2012 Camaro 2SS/RS
Take a look at your headlights on traffic. If you're behind a car at a light, and your lights shine up half of the car you're good. If it shines in their back window the hids are too high.
If they are ok and people keep flashing you, a good middle finger out the window is your best solution lol
2012 2SS/RS Camaro~Imperial Blue Metallic~LS3~M6~GM High Spoiler~GM Ground Effect~GM Tower Brace~Heritage Grill~Roto-Fab Cold Air Intake~Stainless Works Exhaust~Stainless Power Headers~VMAX Ported Throttle Body~BTR Stage 4 Cam~BTR CNC LS3 Heads~FAST 102 Intake~1LE 3.91 Gears~LPW Rear Cover~GEN5DYI Spare Clutch Reservior~Barton Short Throw~ShowStopper Side Markers~UMI Performance Trailing Arms~UMI Performance Tunnel Brace~Elite Engineering Catch Can~VMR V710s
Swacer is offline   Reply With Quote
Old 11-03-2012, 10:06 PM   #8
Mil
Drives: 2013 Victory Red w/ automatic #671
LOL.. i did that .. i can only imagine that they're saying WTF as they're passing by after they flash their highbeams at me from a far.
Mil is offline   Reply With Quote
Old 11-03-2012, 10:17 PM   #9
DRTH VDR
DRTH VDR's Avatar
Drives: 2012 triple black ZL-1 #799
................... people don't realize that you can't have fogs and headlights on at the same time... I drive with my fogs on all the time.
Fogs and low beams can be used together on every ride I've had for years. Fogs go off when high beams are selected.
DRTH VDR is offline   Reply With Quote
Old 11-06-2012, 02:19 PM   #10
evonschu
evonschu's Avatar
Drives: Camaro ZL1
With how many people that have HID drop in kits on lifted trucks out there I find it amusing that people would flash you in a stock ZL1. I have it rigged up so my DRLs are on at night with 7.5W LEDs, and 6K HIDs in the fogs and headlights on my ZL1. I still haven't got flashed once.
evonschu is offline   Reply With Quote
Old 11-06-2012, 02:32 PM   #11
littlecammi
littlecammi's Avatar
Drives: '87 Pontiac Fiero GT
Try handing out beaded necklaces during Mardi Gras in New Orleans. That should get you flashed.
littlecammi is offline   Reply With Quote
Old 11-06-2012, 02:37 PM   #12
rocketman 12
SOON.........
rocketman 12's Avatar
Drives: 2010 ABM SS/RS Z-281LE
No, it's not a real Z/28.....
rocketman 12 is offline   Reply With Quote
Old 11-06-2012, 02:42 PM   #13
trewyn15
trewyn15's Avatar
Drives: 2004 Monte Carlo LS
If it's good looking women 'flashing' you.. I'd continue on with the beams where they're at.
Seriously though, seems like you may have a beam that is mis-aligned or maybe a bulb that isn't put in correctly, giving off a weird glare.
2004 Monte Carlo LS - 1966 AMC Rambler Rebel Classic - 2000 Trans Am WS6
trewyn15 is offline   Reply With Quote
Old 11-06-2012, 10:24 PM   #14
Nadine
Drives: 2013 ZLl
I was able to find adjustment screw above the lights turned them down using garage door as a reference this helped. Not fun on two lane highways with very little traffic hit you with the brights to warn you.
