sjm autoprod
Old 11-03-2012, 07:21 PM   #1
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Peg-leg burnout...kinda
Twice now, on the 3rd pass of a set of hot-laps, the diff on my car felt and sounded 'funny' and only did a 1-wheel burnout.
After having a chance to cool down, it seems fine. Is it possible that heat can cause the diff to slip rather than both wheels grab?
Any suggestions for trouble-shooting? It might be a bit problematic to get my dealer to replicate this issue and fix it under warranty.
Specifics:
Stock 2011 Automatic SS (except it has a cold air intake)
18" MT drag radials
36 passes so far (18 w/ drag radials)
Diff fluid changed at 1500 miles (13k total now)
Three of Swords is offline   Reply With Quote
Old 11-03-2012, 07:35 PM   #2
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
Well an LSD requires an additive in the gear oil in order for it to work properly. Perhaps a fluid change would help? It's interesting that the problem went away once you let things cool down.
Are the noises still present? Was is just the right wheel that was spinning?
Spektrum is offline   Reply With Quote
Old 11-04-2012, 12:36 AM   #3
Three of Swords
Actually, if was the left spinning. From what I've read, the right is normally the culprit when someone has a single tire spin.
As for fluids, I did use the GM additive. But I'm considering swapping the fluid again just to see what will happen.
Old 11-04-2012, 06:42 AM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
The additive is actually what helps let the clutches slip, when say you are going around a corner.... forget to add the additive and your rear will start chattering when you turn since the clutches will have a harder time slipping... the additive is know as "friction modifier"... The problem almost sounds like too much additive, but not sure what that would actually do...
scrming is offline   Reply With Quote
Old 11-04-2012, 06:43 AM   #5
scrming
scrming's Avatar
If the left tire is the one with a less traction it is the one that will spin...
Reviewing the video, it appears that both tires were spinning....
Old 11-04-2012, 07:19 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
This video was taken by my son during the event at Lapeer Dragway 11/3/2012. This shows what Three of Swords is talking about when he says it was only doing a one tire burn out.
I am currently down loading one of his two tire burnouts and will post later.
One tire burnout.
Two tire burnout
Last edited by rtcat600man; 11-04-2012 at 09:10 AM. Reason: added the two tire burnout
Old 11-04-2012, 07:20 AM   #7
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Are you sure that you got enough water on both tires before doing the burnout? I had this happen a couple of times and it was because of this. This is especially true if the tires were already hot and sticky to start with. The wet tire will spin and the dry tire will stick. As the tires cooled down, it made it easier for them to both spin.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 11-04-2012, 09:11 AM   #8
scrming
scrming's Avatar
from the passenger side...
Old 11-04-2012, 10:18 AM   #9
Three of Swords
Just saw the videos. hmm...
I guess I could be wrong about the burnout. It felt and sounded the same way as this spring when the crew member told me my right side wasn't spinning (I actually had to wait until the water drained off the tire). There was a low grinding/rumbling noise and a weird vibration.
It could have been a water issue. They back you into the water pit, but if I wasn't lined up properly, I could have had very little water. And it was the 3rd pass. So the tires would have already been very hot.
Next time, 3rd hot lap, I'll just dust them off and see what happens.
Old 11-04-2012, 10:28 AM   #10
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
This is a very common problem w/ the SS. Once you get some DR's on w/ traction or higher HP you'll start to overpower the clutches in the rear end and get the one wheel spin. Ted Jannetty sells a posi mod that corrects this problem.
http://www.camaro5.com/forums/showthread.php?t=126085
http://jreperformanceparts.com/techn..._store=default
Old 11-04-2012, 10:37 AM   #11
scrming
scrming's Avatar
would you expect the clutches to make the grinding/rumbling noise described?
Old 11-04-2012, 10:49 AM   #12
mlee
www.CamaroFans.com
mlee's Avatar
Not at all... I missed that post and just read it. Don't know what would cause that.
But the Posi mod comes with a new stiffer spring.
Old 11-04-2012, 09:00 PM   #13
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
It's always my passenger tire that spins and the drivers that doesn't. When I leave the track the passenger bumper is covered in rubber and the drivers side looks like I just washed it :(
Gotta get that fixed over the winter.
AngelSpeedFreak is offline   Reply With Quote
Old 11-04-2012, 09:45 PM   #14
spyderbuddy
spyderbuddy's Avatar
All I saw was a V6 whipping up on a V8. Oh yea.
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
